| THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Sent my three circuit dominator to Shaker455HO (Jeff) for a two circuit conversion and let me tell ya, I could not have spent smarter money. Not only did he do the conversion, but he hand delivered the carb back to me and then he and Len Caverly (yeah, the Engine Masters guy) together spent the next 4 hours tuning my combo on the car. Oh the carb ran great right away; that wasnt what needed the tuning. It was my distributor that was all out of whack, and they fixed it right in my own garage. Who does that??
Jeff had some idea from our conversations that my HEI may be causing some issues so he came prepared with a trunk full of tuning equipment and some custom machined bushings to straighten it all out. Sure enough, as we dove into it he discovered the HEI was taking 3-4 degrees out of the initial timing once the car was placed in gear. Fixing this cured my low rpm stall. And here I was always chasing the carb as the root of that problem. On top of that, we discovered the distributor was adding in way too much timing as the RPMs increased. This distributor had been curved some years ago and the car doesn’t see a lot of run time. I would never have thought the springs were giving up. Sure enough though, the springs in this dist were fatigued. Changing them out and modifying the curve just a tad made the car run so much better. I dont know about you guys, but living in the big city like I do where neighbors dont talk, crime is high and people are all in it for themselves, its hard to remember that there are people out there willing to step in and help. And a day where I can learn from some guys that clearly have their heads on straight, talk Pontiacs and have fun with strangers like we've been friends for years, is a day well worth having. So to anyone wondering if Jeff is the man to make this happen, rest assured not only will he do the job professionally, on time and with pride but he'll stand behind it all once its out there and on your car. On top of that, for two guys that know a whole hell of a lot of Pontiac knowledge, they never once came across as arrogant or pompous. Just two great guys helping out their Pontiac brethren. They’re a credit to our sport and the Pontiac marquee is better for having them. Good to meet you Jeff. Extend the gratitude to Len again for me too, will ya? His insight into intake manifolds, engine plates and pump gas, camshafts, cylinder heads and everything else we talked about has me ready to make some changes to discover more power. We'll see each other again for that track rental. Maybe the TA will make an appearance? Be great to see it. Work on Len too – Id love for him to roll out some of Pontiac missiles. Mark
. Mark S . Who needs nice and pretty, when you can have mean and nasty? KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs . So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine! >>My 73 Build thread |
Jeff AND Lenny in the same place, WOW!!
Jeff tuned my car, and lenny ran some head numbers for me once on a flow bench, after which he spent days porting my old 13 heads for another competition! Jeff also alerted me to HEI issues mine had, and I was thinking carb as well. You got some first rate attention there Mark, Grats!
" Long may we DRIVE !" |
Mark,
We had a great time working with you and we'll hook up when your ready to run the car at NED for final tuning. Maybe once we're done you can run it on a chasis dyno local to me and post your results? Thanks again Jeff
Carburetor building & modification services Servicing the Pontiac community over 25 years Last edited by shaker455; 02-23-2011 at 06:22 AM. |
You bet Jeff. Just point me in the direction of who you like up there running the dyno and I'll set something up when the time comes. I wouldnt mind having some numbers for this setup.
Ed |
Yes two very great guys. I can't count how many times they have helped out.
Send it! It’s going home on a trailer. |
He spent a few hours tuning my old combo in his driveway,while running ideas by Len. Let me tell you,the car ran awesome when done. I`ll be sending my two Dominators up to Jeff when the new motor is closer to completion. Cant wait to see what he can do with an all out race motor.
`70 Firebird,Original Owner car Ken French Built Chassis Carlquist Competition Engines IA2 505 Competition CNC Ported Super Chiefs CCE Ported Gustram Twin Dominators from Shaker 455 963 HP `09 Electra Glide Standard. `03 F-350 7.3 6-speed 4x4 Crew Cab Dually. |
This is why Jeff is doing my Dominator. Of course he's invited to come over and help tune my combo.
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected] 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1972 LeMans 350 Pontiac H/S Drags project |
Always great to hear such stories about Pontiac stalwarts. Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Jeff worked his magic on my carb also. He went above and beyond on my car. Did the wideband tuning, also working on the HEI just to make the thing work like it is supposed to.
I am glad you posted this. I have not seen him post in a while, and I thought he took a sabbatical from the hobby I am hoping to catch up with him someday, and with the help of Len, give my old 'bird some more oomph
Panos Little Miss G Racing on Youtube |
I would be happy to come down and I offer Fly-N-Tune. You buy me a round trip ticket and I tune your car for the weekend.
Carburetor building & modification services Servicing the Pontiac community over 25 years |
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
This is not the 1860's silly guy!
Okay..Okay I'll take the balloon! Do I get lunch????
I've said it before and I'll say it again. There are only two kinds of Pontiac people. Those who Jeff has selflessly helped, and those who Jeff will eventually selflessly help, LOL! Seriously though, Jeff is one of the best people I've ever had the pleasure to meet!
John ![]() "There are no stupid questions, but there are a LOT of inquisitive idiots!" |
Winds going in the wrong direction!
I better leave early then!
Jeff and Lenny helped me out with my own 428ci engine. And it's not just that they do. They are also tapped into an extensive network of like minded individuals who do bodywork,have blocks,parts etc. I'm lucky enough to live fairly close by here to those two. Bravo zulu to the both of them Lenny and Jeff.
Thanks Guy's
