View Poll Results: Should The Jigs Be Powder Coated/Painted For You To Invest??
Yes 3 10.00%
No 27 90.00%
Multiple Choice Poll. Voters: 30. You may not vote on this poll
Old 03-13-2011, 04:43 PM
SD421's Avatar
SD421 SD421 is offline
Default Should Manufacturing Jigs Be Pretty?
If you were asked to invest in a company that did manufacturing,
should the jigs be spotless, powder coated/painted for you to even consider making that investment??
Please vote yes or no.
Thanks,
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 03-13-2011, 05:01 PM
A.J.'s Avatar
A.J. A.J. is offline
Since I'm working in the aircraft manufacturing business (Saab) I'm a bit damaged.
The jigs should be clean and painted with ok finish. This makes it easier to see any damages that might affect the tolerances.
If I were looking for a vendor I would surely look at the finish of the jigs in which "my" parts was manufactured in.
Reef turqoise -66 GTO
Firebird Convertible -68 R.I.P.
-73 LeMans 350/350 Barnfind
Old 03-13-2011, 05:15 PM
arbys's Avatar
arbys arbys is offline
A.J. said it well. Also if the manufacturing company cut costs there where else had they cut cost/quality? First impressions are lasting.
Old 03-13-2011, 06:06 PM
SD421's Avatar
I should have been more specific. If the jigs are used for holding metal tubes in place for fitment & welding, should they still be presentable? Im going to reword the main question.
1966 GTO
KRE Tri-Power
Old 03-13-2011, 06:12 PM
MYGOAT's Avatar
MYGOAT MYGOAT is offline
They need to be fit for purpose.
I used to work for a very large Japanese tier 1 supplier to the auto business and they were anal about everything looking pretty. Pity they were functionally crap.
Old 03-13-2011, 06:17 PM
If the jigs are accurate and well-designed they don't need any kind of cosmetic finish on them. Something to prevent corrosion is a plus if that will become an issue.
I see absolutely no need to add any unnecessary expense to manufacturing tooling.
Welding jigs don't need to be pretty, just functional.
Old 03-13-2011, 10:41 PM
shaker455's Avatar
I'm a toolmaker and although it would look nice for a short time the jig will see heat from welding and will get chipped and blister even if it's powdercoated.
Old 03-13-2011, 10:58 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
My welding Buddy makes it sound like he is always making jigs on the table for this or that and cutting them off later. IMO a jig should make it easier for you to do your work properly and not a piece of shiny ?? in the corner. If I seen a metal shop with shiny jigs I think I would be looking at a shop with a very high overhead or no work
Old 03-13-2011, 11:00 PM
02Hawk's Avatar
02Hawk 02Hawk is offline
For a welding shop ....no....should the finished work be pretty....yes
What I look for
1) Is the shop clean?
2) Are the bathrooms clean?..plenty of TP, soap and hand towels?
3) is the lunchroom/coffee area clean and cheerful
4) do the guys have music going?
5) is all the safety apparatus and signage located in designated areas and free of dirt and debris?
6) Do the people in the shop acknowledge people coming into the shop on a friendly and business like way?
I would need yes to to the above in order for me to work and or be an investor there.
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright"
Old 03-13-2011, 11:25 PM
the-rookie's Avatar
the-rookie the-rookie is offline
Send a message via Yahoo to the-rookie
Welding Jigs? No absolutely not.
As said above LOL in some nice comments As long as they are well designed, fit the product well and are functional is the main thing. ease of use and functionable.
Old 03-14-2011, 12:39 AM
regamble regamble is offline
The first jig I built was done so with painstaking care, lots of very pretty welds instead of tacked together, painted, etched marks for product weld points and drill points. After 3 weeks of use it looked like someone had beaten it with a hamme and I was rebuilding it all over again anyway. My jigs are now 100% functional so as not to increase overhead. Labor is expensive when someone spends a lot of time adding visual to functional. If investing in a business I would not allow this to become a factor unless it was the only factor, agreeing essentially with 02hawk.
Old 03-14-2011, 06:30 AM
stimpy stimpy is offline
I look at form and function not smoke show . I used to go to alot of major shops when I hauled steel and the jigs well... they looked ratty , but the product they made looked real good , and I am talking about a major engine producer that made there engines from weldments . as long as th shop is clean , and produce a good product thats all what counts , if they are on making it look pretty image , thats a money waster .as they have to devote labor and time to keep up this image which can better off be used to make product .
Old 03-14-2011, 08:15 AM
69goatboy's Avatar
69goatboy 69goatboy is offline
What B-man said.
If it's a welding jig, one thing I would look at the quality of the welds. Nice, clean beads that are only as large as they need to be with splatter cleaned up would tell me much about a company making a welding jig.
Fillet welds that look like a first grader globbed them in there with a tube of toothpaste would tell me much as well.
Since it's a welding jig, paint of any kind will only burn and affect how your tubing will sit in the jig. Powdercoating can be .010-.015" thick.
Also, did they cheap out on the quantity and quality of the clamps?
Golden rule of anything mechanical: fit, form, and function. Everything else is window dressing.
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 03-14-2011, 11:12 AM
SD421's Avatar
Great responses. The reason for my post was from an argument I had had with a header shop's business partner.
He had said that the owner needed to make the jigs look more presentable ie.. painted or powder coated for another investor to even think about coming into the shop to invest.
My argument was not to coat or paint them because it was a waste of time and money.
Don
1966 GTO
KRE Tri-Power
Old 03-14-2011, 12:21 PM
iceman411's Avatar
iceman411 iceman411 is offline
Pretty or presentable..Not really. At Magna in Clinton TN they got pretty trashed even with only a month of use. With the everlasting amounts of adjustments on a strict time frame, we get pretty mid-evil on them with hammers and such for the mildest shim adjusments and the operaters get down right nasty with them with abuse from bigger hammers than we used..LOL... We fixed alot of broken dowels and screws along replacing "missing" gauging blocks..Cycle time of the cell process to bring costs down would be more impressive
Old 03-14-2011, 01:10 PM
I work in Metalstamping. And I've seen stamping dies that are polished and can hold tolerances of .0005 and are beautiful to look at. I've also seen dies that are literally stored outside. And everything in-between
It just depends on the application
Old 03-14-2011, 01:55 PM
klunker klunker is offline
As the former Owner of a Tool and Die shop that made fixtures for welding if someone wanted weld fixtures painted I'd do it if he was willing to pay for it. I NEVER would do it other wise. It is a waste of time and money and has no functional value!! If I was looking to invest in a company that did that I'd see the company as inefficient. If someone wanted to invest and to impress them I found out they like things looking pretty I'd make sure they had no say in the operation of the place as they obviously know nothing about manufacturing.
This function over form argument is absolute in manufacturing. Any time/money spent on making tools/dies/fixtures look nice for appearance sake is WASTED PROFIT.
Old 03-14-2011, 02:33 PM
Coach's Avatar
Coach Coach is offline
Spend the time and money washing / painting the walls and the light fixtures. I am way more interested in a clean, organized, and well lit environment then painted jigs.
I worked for several manufacturing shops over the years and the successful ones were the ones that were kept up. At Rexnord Bearings we always stopped 15 minutes before the end of the shift to wipe down the machines for the next shift. That was back in the 70s. I believe that plant is still in Downers Grove to this day. One of the few that are.
-H
Sold - 1967 Grand Prix Convertible ( http://forums.performanceyears.com/f...d.php?t=639110 )
2003 Bonneville coupe (hers)
2007 Avalanche LTZ 4x4
