Old 03-08-2011, 08:54 PM
codyyy's Avatar
codyyy codyyy is offline
Default Quick question about 400s
I recently talked to someone who has a '76 400 for sale. He says it will not fit into my '68 GTO because something about the way the mounts are setup (I think). I would assume I would change the motor mounts, but is this really true? I thought the 400s were kept basically the same throughout the years except for small details. Thanks.
Old 03-08-2011, 09:03 PM
adapter plates are available
former." --Albert Einstein
- Winston Churchill
Old 03-08-2011, 09:19 PM
ErikW's Avatar
ErikW ErikW is offline
Read this
http://www.pontiacstreetperformance....p/blockID.html
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 03-08-2011, 09:35 PM
ErikW's Avatar
Our host lists this:
RFE139B ENGINE MOUNT CONVERSION BRACKETS. (Inquire)
so I am not sure they have them available.
However, Ames lists them:
N244A 1976-81 Engine Mount Adapter Kit (RE)..................... $53.00/kit
Hope this helps.
Erik
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 03-09-2011, 12:23 AM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Some engines were drilled with multiple mounting holes to allow installation in nearly ANY pontiac that would have a v8. Some engines only had a couple of mount holes drilled/tapped. You can either buy the adapters or you can drill/tap the holes on the bosses that exist on the block.
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 03-09-2011, 12:33 AM
codyyy's Avatar
Ok I will check into that, thanks. Good to know I can still use this engine somehow. Is it an easy conversion?
Old 03-09-2011, 12:38 AM
Sirrotica's Avatar
76 should have the early and late bolt patterns, 5 holes in each side, 77 was the first year to only have the late pattern 3 holes only. To answer your question 68 mounts should bolt to a 76 block, no adapters needed.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-09-2011, 11:40 AM
johnta1 johnta1 is online now
Sirrotica is correct.
The problem is going the other way - you need an adaptor to put a 68 engine in a 76 car like a Firebird.
1970 to 76 engines will fit into any Pontiac car except the early front engine mount cars.
Old 03-14-2011, 09:50 PM
codyyy's Avatar
Ok so I picked up a slightly different 400. The big numbers to the side of the distributor say 550557, which is a late 75-76 engine. However it looks like this 400 only has 3 bolts per side and I don't think any bosses for any other mounts. I could be wrong.
Old 03-14-2011, 10:42 PM
pontiac6269's Avatar
pontiac6269 pontiac6269 is offline
Post a picture of the sides of the engine. I have a 77 400 4 barrel out of a Firebird that does't have the mount holes for the earlier 2 bolt mounts.
Eric
1969 GTO - 461, turbo 400, Continental 13", 3.08 gears. - 12.59 e.t. @ 108.43 mph, 1.898 60'
1978 Oldsmobile Cutlass Supreme- 461, turbo 350, PTC 3500 converter, 9" 3:50 gears. = 11.39 e.t. @ 117.55 mph, 1.599 60' on E85
Old 03-14-2011, 10:45 PM
Sirrotica's Avatar
It's most likely a 77-78 as these are the only years that had only the late 3 hole motor mount bolt pattern. The year is most likely, but not always, 77-78, next to the distributor in 2 digit form there is also a longer date code cast in if the 2 digit number is absent. The 557 is probably the weakest Pontiac 400 block. Good at least for a strong street engine 450-500HP safely. Good to hear you finally found a usable block locally.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-14-2011, 11:15 PM
codyyy's Avatar
The numbers I have are:
Next to the distributor 9101
Front pass. side WA (no numbers above that)
Front lower driver's side 27N108574
Hope this helps. The engine has a mild cam and some work done to it. Is there any way to strengthen anything on this block?
Old 03-15-2011, 08:08 PM
codyyy's Avatar
I'm guessing I'll need to buy adapter plates. My coworker looked at the engine and said I can get away with reringing the engine again and honing it, however he thinks I got screwed on the price. I paid $700 for the shortblock. It was either this or a running $650 76 GP motor with unknown miles.
Pics:
