#1461
Certainly not the driver.
#1462
Maybe they could see into the future and figured that in 40 years, due to global warming, the sun reflecting off the guy's mirror housing behind you, would shine into your rear view mirror and then flash into your eyes and distract you from texting on your cellphone, while eating a cheeseburger, and chugging that 72 ounce Big Gulp with no cupholders. Can't be too safe, ya know.
#1463
The DOT mandates were actually for the Calendar year, so bolt on options waited till the actual calendar year to implement. Example of NOT waiting, is side marker lights in 68, however, the shoulder straps were NOT installed untill Jan, 1968.
Great analogy Steve!, but true was the refection. The upper window chrome on top of the windshield was full chrome in 67, and brushed aluminum look on back half in 68, as well as the horn button and steering wheel chome to brushed. This is why the 1970 chrome rings on gauges surprised me.
" Long may we DRIVE !" |
#1464
Not being satisfied with the wrinkles that were left in the back edges of the headliner after my amateur installation a year or so ago, I took the car out for a 70-mile round trip drive today, to a long-time upholsterer I have used for other work.
He's been doing this stuff for 45 years and he still says he's learning new methods every day. After about an hour or so of tugging, heating and massaging, all the wrinkles are gone. He said one of the mistakes people tend to make is not to trim away enough of the fabric channel that holds the metal bows. If there is too much of the channel still attached to the headliner on the ends, it will cause bunching and wrinkles in the edges and corners. All in all, he said he has seen a lot worse backyard jobs than mine, so I guess that was a compliment. (P.S. I think it's time I cleaned the camera lens.) ![]()
#1466
I've gone over this post a few times since it started...I may be doing the same to my 76 it has been heavily oiled since new and at one time the underbody was sprayed white.The white is starting to peel very easily you can rub it off with a rag no problem...underneath is all the factory red oxide primer.Once it warms up around here I will be powerwashing the undercarriage to its original primer.
#1467
Did the annual oil change yesterday. I put 1,150 miles on her since the last oil change in April of last year. Five quarts of Castrol GTX 10W40 + a can of STP + 3 ounces of Camshield zinc additive.
Changed the plugs back to the NGKs. It really runs a lot smoother with those NGKs in. I had swapped back to the set of Autolites during the ignition trouble-shooting episode a few months ago but I noticed it runs "different" with the Autolites - it kind of surges at a steady RPM. That doesn't happen with the NGKs. Took her out for another spin today to test drive the new oil (needed an excuse). I'm beginning to like this thing. |
#1468
What height did you end up setting the float?I'm taking Lloyds advise on the jets and rods as well!thanks,Tom |
#1469
I set the float at the 1/4" factory spec in the 72 service manual, which Lloyd agreed would be the better setting. I think he was just ballparking the figure.
As for plugs, I bought a one step colder set of UR5GP NGK plugs to see how they burn. After 35 years of wrenching I'm still learning about stuff, like how to read the electrode and where the burn mark should be. Here's the UR4GP, burning a bit too hot, as the flame mark on the electrode is closer to the base than it should be. (Too close to the tip would indicate too cold of a heat range). ![]() And the UR5GP burning the preferred area, halfway up the electrode: ![]() And here is the base ring color with a consistent brownish tone, allegedly indicating proper carb jetting/fuel mixture: ![]() Any tuning gurus out there, feel free to chime in with your opinions! This looked like an interesting article on plug reading: http://www.wallaceracing.com/plug-reading-lm.html Last edited by njsteve; 04-10-2011 at 12:52 PM. |
#1471
Steve - that is one of the lost crafts; tuning an engine like this. I have a good resource here in Atlanta - a guy who started out back in 68 working for a Pontiac dealership here in town (Boomershine). He now does all my tunning work and my car runs amazing! He has one of the old Sun machines and knows all the tricks. I'm going to share these photos with him. Cool stuff, thanks for posting.
BJ
1971 GTO 455 HO 4-speed - Cameo White, White Vinyl Top, Jade Green Interior, Ram Air Hood, AC, Honeycombs and 8-track 1974 Formula 455 I Owned in 1975-1976. Now Own Its Twin From Same Dealership |
#1472
I have an old Sun machine too. Bought it ftom a local Chrysler dealership. Same type I trained on in 1980.
#1473
My new (old) project, in case anyone is interested in the start of another (hopefully not neverending) thread. It's located in the 74-76 Firebird Section. :-)
http://forums.maxperformanceinc.com/...d.php?t=664082 |
#1474
Thanks for the heads up Steve - now suscribed and look forward to following the new thread as well.
BJ
#1475
Had a fun time at the Performance Years Open House yesterday. Great bunch of people there. Hung out with a few other members of the site. Here's a shot of their 71 and 70, next to my 72.
![]() Also spent some time with Tom D, and his High Performance Pontiac crew. They spent a good two hours shooting the T/A at a nearby barn, in the early evening. (You have to shoot a white car either first thing in the morning or the last thing at the end of the day, in order to get the exposure right. Here's a sample shot with my point and shoot camera at about 7:00 PM. ![]() The car performed flawlessly. It was only 45 miles or so, so my son and I drove the leisurely hour to get there. The only stop was to rescue a female box turtle trying to cross Route 202 in PA. The return trip was fine too. Ended up using a quarter of a tank of gas for about 90 miles of travel. We had the A/C going full blast on the way home. It was definitely a hot and humid day. Despite the heat, the temp gauge never went above 165 or so (stayed below the first notch on the gauge the whole day). Last edited by njsteve; 05-22-2011 at 11:39 PM. |
#1476
Hi New Forum Member here...Great Thread. Car looks Great.
#1477
Welcome.
#1478
Martin1264, welcome to Poncho-Villa, the house of Pontiacs! :-)
Where in CT are you? I grew up outside of New Haven. |
#1479
Thanks....
from Southern CT...Redding/Newtown areaMy 1973
#1480
Thank you ....I'm in Southern CT Redding/Newtown area.Again Great Car... Was this in HPP a few months back? |
