Nice Picture, Bart, and totally understandable. That engine is going no where.
Tom Vaught
the only problem i have is room. i have an alternator, PS pump and stock exhaust logs facing backwards so they dump out the front of the motor in my turbo setup. i was thinking maybe the plate for the back of the drivers side head but there isnt much room there either.
Vic in SoCal. Follow me on Instagram- Cloud9orbust 66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi. ![]() My T56 Install My Turbo Build My Vortech Supercharger Build Hyd Throw out bearing Misc Build Pics May the Karma Gods meet you half way.... |
Perhaps you can make up a longer more elaborate tiedown bracket out of 5/16" or 3/8" steel plate (depending on bracket length) attached behind the accessory bracket on the front of the cylinder head that will reach over and past any obstacles, like the front-dumping exhaust manifold. Mill down the accessory bracket on the backside to match the new bracket material thickness. You can then attach a chain or turnbuckle to the frame. I used a long 3/8-16 Grade 8 bolt and drilled through both walls of the frame to attach the bottom link of the chain. Get out some heavy cardboard and start making a bracket template. Good luck, Bart |
There is another mod where you weld a piece of steel rod across the tab interlock. It allows about .03-.06" travel and then it is basically a solid mount. i found a pic of it once upon a time, very inconspicuous and simple.
Bolt your own motor mount?
Only problem with a regular bolt is clearance to the frame bracket. Can either notch that, or shave down the bolt head...
Check out post #8 in this thread:http://forums.maxperformanceinc.com/...in#post3555937 |
yes, that is what i had envisioned. i took a look at it today. looks doable but i will have to mess with moving the power steering hoses a little bit. I still havent ruled out the back of the head. with exception of a tight fit against the firewall and alot of fuel injection wiring i have a ton of space...... and just as i wrote that i had an idea....what about the utilizing the bell crank pivot hole to mount up something?
