Old 03-28-2011, 11:04 PM
Originally Posted by 6D6GOAT View Post
I had thought of that set up but became concerned about the torque applied to the front of the head. I figure that a 6 to 8 inch lever plus the torque of the motor at full squirt, 10 pounds of boost etc would/could cause some problems with the head lifting, twisting or distorting? i dont know, am i being too much of a puss here? am i over reacting on the forces at work here?
Yes.
Check out post #8 in this thread:http://forums.maxperformanceinc.com/...in#post3555937
Old 03-29-2011, 12:28 AM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
yes, that is what i had envisioned. i took a look at it today. looks doable but i will have to mess with moving the power steering hoses a little bit. I still havent ruled out the back of the head. with exception of a tight fit against the firewall and alot of fuel injection wiring i have a ton of space...... and just as i wrote that i had an idea....what about the utilizing the bell crank pivot hole to mount up something?
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 03-29-2011, 12:36 PM
I'm not sure if the block casting is stout enough in that area. I wouldn't put all that force on only one bolt attached directly to the block casting, a stout bracket bolted to either the front or back of the head with 3 bolts would be a much better choice in my opinion.
