Well, talked to Paul after lunch today and he told me the SS plate from Ames was a perfect copy of the last version of the plate designed by Pontiac. Says with all the motors he builds he always bangs on the plates! To me, the pictures of the Ames SS plate which I have, shows it has no curvature to match the impeller. It is almost flat across, while the original has a bow in the plate that matches the blades of the impellor! Talk about a conundrum!!!! I’m trying to find an original plate for my car that is functional and can be cleaned up! I’ll powder coat or anodize it to prevent corrosion! If anyone has an original plate for a 66 or 67 GTO. Please email me at: [email protected] I desperately need to get my car on the road! This is crazy! We get Cordone on board and now we still have a problem with the plate and I’m not banging a plate! |
Dan the SS plate issue being looked into by Ames Engineering. Hopefully they too will see a change is needed.
The SS plates might have been good enough for the shaved impellers we had trouble with, but that is no longer true. 3 of us have seen these plates are no longer 'good enough'. These new impellers that are correct need a plate that has the full curve in it... just like the original plate with the keyway. Even the plate Pontiac changed too had the full curve in it minus the keyway. There is no reason why these SS plates should be beaten on to make them work.... not any more. Besides, it's very iffy if the SS plates can even be beaten so they'll work with correct impeller Cardone is going to use. If they can it will be a long slow process... and that's from a machine shop. Two wrongs don't make a right. Pontiac didn't beat on any plates they used, so why should we have to.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
| The Following User Says Thank You to GT182 For This Useful Post: | ||
It's great that board members took the time to work with Cardone and that they appear to have fixed their pumps.
I'll tell you from the past experience working in the custom auto parts industry that coming back to them over and over with an issue you think is there's and isn't, is going to wear them out. I'd take some time and then more time, making sure what you're sending them is accurate info and accurate parts because the reality is, their Work time is more valuable than your Free time to get parts made. Looks Cardone fixed their issue and the new pump is better with the stock plates. Looks like Ames isn't making the most accurate plates. I wouldn't have Cardone do a darn since it looks like they did their job correctly and I wouldn't bother them to reconfigure the new pump around someone elses part miscalculation. Please don't say you're trying to now have Cardone make the new pump around the Ames plates, that's a door slammer if I were Cardone and everyones hard work and time could be flushed away.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
On the contrary, we are working to get Ames to correct their mistake, and I take my hat off to Gary Carr and Charles Broussard that are taking the lead! One down and one to go!
If they don't resolve their problem, then we are looking into manufacturing the proper plates ourself possibly! |
Great job guys!So how much taller(vanes) is the new over the old?I think I have a good original plate,not sure where since I moved.
![]() New pump, with same original plate. ![]() Enough said? Charles |
Still haven't heard on a part number yet from Cardone. As soon as we do it will be posted here, and I'm sure PY and Ames will both carry them. You should also be able to get them thru the parts stoes like NAPA that do carry Cardone waterpumps. For the guys around where I live, Christianna Auto Parts in New Castle carries Cardone. I'm sure they'd be happy to send out these pumps to anyone that needs them.... once they're out on the shelves or you're able to order them. As for the repo SS plates, Ames Ent. is still checking things out. I called yesterday to check. But do to family issues the 'Boss' has been away taking care of that.... I was assured will get it resolved one way or the other as soon as possible. Had the car out this morning for a 10 mile run and all is well.... Temp went to 190 when stopped at traffic lights but came down to 180 as soon as I started moving again. IMO I think the problem has been solved from Cardone's end.
