Old 04-05-2011, 08:42 AM
grandville455's Avatar
What is the bolt thread on the bolt that goes thru the mount? How long also
Darby
M/T 275/60 ET SS Drag Radial
Old 04-05-2011, 02:02 PM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
im looking at a 1/2 inch bolt coarse thread, length to be determined.
Sirrotica, lol, yes, my curse. i always try to make things juuuust a little bit better than before.
It drives my wife crazy whether we are planning something, making dinner together or remodeling the house.
so that is why i see that a chain bolted to the frame has worked for countless people but i just want to take it to the next level. it seems easy enough to incorporate a urethane bushing and as i mentioned earlier i feel that it will still take out the shock when the chain runs out of slack as im banging through the gears.
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
Old 04-05-2011, 02:22 PM
6D6GOAT's Avatar
here id a pic of the bracket. this will be the view if looking at the back of the drivers side head from the driver seat. the chain will be welded to the 1/2 bolt with a nylon locking nut on top. the chain will be bolted to a bracket welded to the frame. with the nylon locking nut, it will make it adjustable. i also plan to weld in a shallow bucket top and bottom to keep the bushing centered.
over engineered...yes..better than a chain bolted to a motor? time will tell.
ID:	240254   Click image for larger version
My T56 Install
My Turbo Build
Misc Build Pics
Old 04-06-2011, 02:41 PM
JC455 JC455 is offline
Looks good, Vic!
That's exactly what I was describing.
John
IG: @crawdaddycustoms
