Old 04-07-2011, 06:54 AM
Old Goat 67's Avatar
The new pump # has not been issued yet. They are working on it as fast as they can, but it does take time. As soon as it has, it will be posted here. Hopefully, in the near future.
The couple of pumps they found in their inventory were flukes located by a manual search. The same situation as the one I found by accident years ago. Pumps with the higher vanes and correct curvature made it through the process without having been replaced with a lessor impeller.
There are no commitments from vendors who will carry them yet either, but we are hopeful that PY would be the first. After all, IT IS this forum that has enabled this to even be possible.
This is the best place for our passion to be made better! AND, I should add, it is free to us.
Charles
Old 04-17-2011, 12:04 AM
aronhk_md aronhk_md is offline
Wondered why I hadnt heard any updates from the old thread....didnt realize there was this new one! lol I'll add my thanks to you guys for your time and energy pursuing this. Even through my disagreement with the "pump engineer" at the end of the other thread I knew banging the plate wasnt the solution and that the impeller needed to be properly positioned on the shaft. I've moved one to the proper position myself, but obviously it would be nice to just buy one that is correct.
On another note.....if you get one of the new pumps before the plate situation is addressed.........you could probably press the impeller very slightly to get the clearance you need with the SS repro plate. Unless it is severely interfering this shouldnt open up the plate to impeller distance more than a few thousandths more yet should clear it for use. We arent talking the 1/4" gaps we had before. GT182..........can you verify this? How much clearance would you need?
