Old 05-01-2011, 08:16 PM
njsteve's Avatar
njsteve njsteve is offline
I pulled the front steering linkage and the steering box, just to clean the encrusted gunk off. The steering box was natural cast finish with an aluminum cover and a pink paint daub on the spline where the steering shaft mounts up.
Dodged a bullet here! Check out the steering box bolt in the center. I used PB Blaster to loosen the bolt but it still took an impact gun to get them loosened. I would loosen, then tighten, then loosen repeatedly, to rock them free. Looks like the center bolt came out just in time. I was surprised it didn't break after seeing how much was rusted away.
Old 05-01-2011, 08:24 PM
njsteve's Avatar
The steering linkage was gunk covered and took a lot of brushing and degreaser to get it clean. You can see the original green paint mark on the driver's side, inner tie rod. (Just like my 72 T/A had). The weird black plastic ball thingy that looks like a toilet bowl float is actually the plastic cover (two piece) that goes over the steering box rag joint and the lower six inches of the steering column shaft. I think this was some kind of safety item to prevent debris, rocks and stuff from jamming the steering if it got caught between the rag joint and the subframe.
Old 05-01-2011, 08:30 PM
njsteve's Avatar
I pulled the brake booster out to clean it up. It had quite a bit of surface rust on it. Soaking it, face down in the safestrustremover.com stuff. Working very well taking the rustiness away.
You can see the light blue inspection mark on the "Delco Moraine" stamp in the 2:00 position on the face.
And on the top was a light blue mark that ran across from the front side to the back side at the 12:00 position, as well as an orange daub right at the top.
Old 05-01-2011, 08:59 PM
njsteve's Avatar
Here's the engine compartment at the moment. I ended up using a little daub of diesel fuel on a rag to clean the firewall and the inner fenders. It worked out very nicely. The dry areas you see on the driver's side of the firewall and alongside the A/C box are the sloppily-applied, factory body schutz undercoating, which I am leaving in place.
And, yes that is a rag covering that cursed open exhaust down pipe.
Some of the cleaned up parts at the moment: the steering box, wiper motor, the steering shaft, the 7042264 1972 400 carb (matches the intake I have on the car), and an extra brand new master cylinder that I had sitting around waiting to go on something.
My parts order from Summit Racing should arrive tomorrow so I can bring the pistons, cam bearings and block assembly hardware over to the machine shop. I ended up getting the entire rebuild kit, which includes .030 pistons, rings, cam, main, and rod bearings in one package. (The crank polished up nicely so I can stick with standard size main and rod bearings.) Since I already had bought a new Melling oil pump and a Felpro gasket kit, they were able to deduct those items from the kit and save me about 80 bucks.
