Update
It was 80 here today and the car started right up after driving it from work . The other day it was cooler out and the car just clicked! Had to sit a few minutes then fired back up. So this definately is a great idea if your having hot soak start problems!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
This is the best one in this forum, with some very knowledgeable people giving advice.
So, I've got my battery cable run as the diagram in the original post shows. However, it's unclear in that diagram where the "S" wire shown goes. I have the BAT and "S" terminal jumped with a piece of 10-gauge wire. I also have a 10-gauge wire from the starter "S" terminal as it shows. I'm assuming the "S" wire goes to the "S" terminal on the Ford solenoid? Also, when I dropped the starter to wire it up I noticed I had the coil wire hooked to the "R" terminal on the starter. Does the coil wire go back on there, or to another switched ignition hook-up? And finally, is the "I" post on the solenoid hot when the ignition is turned on? I used the 2-gauge Belden Ektron cables to wire this up, so my resistance should be down a bunch as well. Wired like this, they are quite a bit shorter than previously. Boy, it ain't no fun to run 2-gauge wire, but I managed and get everything tied down with insulated clamps, and as soon as I get these starter circuit question answered, I'm good to go. Thanks in advance for your advice to a guy who knows f-all about auto electrics. ![]() ETA: forgot one last question. I have a 1-wire alternator that was previously hooked to the positive terminal on the battery. OK now to just hook this to the permanently hot post on the solenoid? That would shorten the wire considerably (and look neater.)
"Democracy is a beautiful thing, except for that part about letting just any old yokel vote." ~Jack Handey, Deep Thoughts Last edited by Bob Dillon; 08-02-2015 at 12:28 PM. |
Putting the diagram on this page to see it easier:
![]() ![]() The 'S' post wire on the Ford solenoid goes to the starter/ignition switch. It's usually a purple wire from the firewall. (also the wire that would normally go to the 'S' post on the original starter, instead of going down to starter wire it to the Ford solenoid) The 'I' wire on the Ford solenoid would be used for a wire that went to the starter originally, if used. (not all cars had them, it provides 12 volts to coil when cranking) The coil ignition wire should not be run to the solenoid if it didn't go to the starter originally.
(the battery side of the solenoid)
