Originally Posted by Bigger is Better
Yes it was, the front windshield is cracked where some thing hit the top of the a pillar, the doors glass was down so I think that saved it and by some odd miracle the rear windshield did not break! It almost makes you think the car is saveable but thats still not realistic.
Are you sure? I know we don't see the frame, or anything underneath the car, but it looks salvageable. I have seen what looks worse than than that brought back. The 2 things that stick out the most is the passenger front, the wheel looks pushed back and if there is frame damage there a new sub frame is pretty easy to find. The drivers rear quarter panel and trunk is bad, but can be replaced. Which ever way you go, good luck, although you already had the good luck. You walked away.
