| Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
This is what is GREAT about our hobby - people sharing information. You have provided an education to an entire group who would not have had a clue about these problems. Thank you!
'68 GTO 4-spd Hardtop (11) '68 GTO Convertible AT (1) '70 LeMans Sport Land of Lakes Muscle Car Classic Facebook Event Facebook Wall (Kurt Smith,Minneapolis) |
I remembered throwing a patch panel in the junk pile because I was not happy with the shape of it. When I cut it to size, there was a bow of about 5/8" compared with the fender. I got out the panel and since I would be cutting several inches off maybe the shape would not be off as much. When cut down if was only about 1/4" of bow so I though I would get it a shot.
First since the bottom part of the fender had already been cut off and used to repair another car, there is nothing to use for a guide. The only solution is to bolt on the fender and align it with the door edge. I had already checked the cut edge of the fender and determined that it was straight. ![]() It is then possible to obtain a measurement to use with the patch. ![]() Then transfer the tape to the patch and mark. ![]() For the front edge it's a little harder and I won't bore you with all the details, except to say I used a bolt hole for the inner fender mount in order come up with a tape for the front edge showing how much to leave. Next thing is to check the edges. On the fender it's very straight across where the cut was made. ![]() However the patch is not straight. This can't be simply bent since the crease near by with keep it front bending. The solution is the put the patch in a stretcher and work the metal until the edge is straight. ![]() After a minute or two with the stretcher and a straight edge to constantly check the work, the edge is straight. I later gently hammered the edge against an anvil and now have the edge arrow straight, it should be very easy to but weld to the fender now that it's straight. ![]() Too late to finish tonight. I don't have the energy I once did. Hopefully I will get this fender done in a couple of days.
68 Lemans - GTO appearance LS3 68 Eldorado - waiting for restoration 96 Roadmaster Wagon 2014 Infiniti Q50S Hybrid Marietta GA |
I didn't get to weld patch on today. It's taking longer than I thought to get rid of the rust on the inner brace. I'm using naval jelly and it can take a while. Forget about the 5-30 minute time on the label, heavy rust pits will take many hours, then you need to clean it off with water, go over it with a wire brush and then apply another coating. It will take several treatments. So far I have applied Naval Jelly 3 times to the brace.
Important note - The gray coating that forms is zinc phosphate. If you are going to use an epoxy primer, this coating must be completely removed. Epoxy will peel off in sheets in a few weeks if you don't remove the since phosphate. One way remove the coating is to go over the metal with a wire brush until it shines. I got most of the rust out of the pits but not all. ![]() I will apply another treatment and let it sit overnight. ![]() Cover your work with plastic to keep the naval jelly from drying. ![]() I am ready to weld the patch as soon as the rust of the brace is treated. ![]() I had to rework the shape here, it didn't match very well. I'm doing this much too often and have gotten very good at it, the first it took me about a hour to get the shape right. I may have spent 2 minutes this time. ![]() In between rust treatment sessions I started joining the broken pieces of my dash panel. This is a first pass on solvent welding the parts together. I still have a bit of work left.
Driver fender continued.
This is the final result of Naval Jelly treatment, this represents 5 treatments. All of the rust has been dissolved from the pits, this is after zinc phosphate has been removed with a wire brush. ![]() Painted the brace with an epoxy paint. ![]() I tack welded the patch panel in a few places and installed the fender to check the contour. From the crease upward the fender matches the door perfectly. From the crease downward the patch panel does not match the contour of the door. I will correct this by using All Metal to get the basic shape. ![]() Removed the fender to finish welding. Tacked welded. ![]() The joint welded. ![]() The weld bead trimmed with a cut-off wheel. ![]() The completed weld. Door side ![]() There is a little misalignment along the green lines. The amount is about the thickness of a Business Card. This occurred because I didn't have access to the back of the joint due to the inner brace being in the way. ![]() I got the instrument housing ready for paint prep. This is result of solvent welding the two pieces together. The housing broke with a crack from the green arrow to the corner of the AC control opening. ![]() The bar was broke at the bottom of the AC control opening ![]() It repair looks good. After being painted the former breaks won't be visible. The housing gets a glossy black finish before chrome can be applied.
I finished the basic work on the driver fender today.
Sanded the backside and cleaned with a degreaser. ![]() Spot welded the brace at the front which had broken free when the fender got banged up. ![]() Spot welded the patch to the brace. ![]() The spot welder I use is sold by HTP. This welder is able to weld through primer and is automatic. Set it for the panel thickness and pull the trigger. The machine does the rest and stops when the weld is complete. ![]() I painted the backside with an epoxy paint. ![]() This puts me one fender away from being able to test fit the front end. Next the passenger fender.
Mostly finished with the rust repair on passenger fender. I ender cutting out most of the section from the top of the fender where it bends to form a channel for the hood to sit in.
Before cutting out so much of the fender it is important to put some temporary bracing to keep the fender from sagging. Any scrap will do, this was some pieces I had collected by my cut off saw (OK I was lazy and didn't throw this junk out right away) but it was perfect for the temporary bracing. ![]() I started cutting and for the first cut I cut out about 14 inches. ![]() How bad was the metal? You can tell how deep the pits are in the photo, but this whole piece was about to become swiss cheese. ![]() I didn't take many pictures of the resulting repair but you can see the completed portion here. And you can see where I had started tacking the next portion. ![]() The next cut removed all of the channel all the way to the front of the fender. I failed to photograph the removed metal but here is the next piece tacked in and then welded. ![]() ![]() And the final result ![]() I have a little cleaning up to do, but hope to install the fenders tomorrow for a test fitting.
It's been a while since I could work on the LeMans, I got covered up with computers to repair, recover data etc. After the storms hit I had 14 computers which took first priority for my time. (I'm self employed and own 2 companies)
I have spent about a day attempting the align the doors and fenders. Part of my problem is I don't know what the gaps were since the fenders and hood had been removed and when reinstalled no shims were replaced and the bolts were finger tight. I can't find any gap information in the service manual, maybe it's there and I missed it. I also suck when it comes to panel alignment and it probably doesn't help that I have to work alone. It looks like panel alignment is really a 2 person job. I will post some pictures in the 68-69 section asking for opinions a little later when I can get some time. I went to install the hood on and found the hood hinges I have are wrong. The hood sits up about 2 inches in the back with the hinge at the lowest position in the slot. I ended up reinstalling the old factory hinges so I can check hood gaps, right now it looks like I would end up with about 1/8" gap. I don't know it this is enough. It's starting to look more like a car again. ![]() I don't know how normal this is but when everything else looks like its aligned good, the gap grows from 3/16" to 1/4" at the top of the fender where it meets the door. Assuming that this is not a screw up on my part, I guess the door or fender would need the be welded to fill this gap. ![]() So far I have identified about a dozen items that need attention a partial list includes 1. Rework the top corner of the rear quarter panel where it meets the door 2. There is still some straighting to do on the driver fender inner bracing. 3. Passenger fender at the very bottom does not match very well to the rocker panel. This was caused by the patch panel not being formed correctly. 4. Driver fender patch panel does not match the contour of the door near the bottom. It did however match the rocker panel. 5 to ? other minor items to deal with not worth listing here.
