Old 06-12-2011, 07:16 PM
79Poncho's Avatar
79Poncho 79Poncho is offline
Default Assorted Pontiac, Oldsmobile & Trans Am Parts
This is the beginning of my foray into selling off some personal inventory to generate funding to finish my '79 Pro-touring TA. All prices are OBO. I can deliver to Trans Am Nationals. This is my first time selling anything like this, so if my prices are way off base, feel free to let me know.
1. Complete "46" code Pontiac cylinder heads date coded J178 & J258 - October 1968, came from a Big Pontiac '69 400. Int. 1.96 Exh. 1.66, 10:1 CR, 75cc. $250
2. Mostly complete "4-77" code Pontiac cylinder heads date coded F145 & F145 - June 1965 origins unknown. 1.92 Int. 1.60 Exh., 10.75:1 CR, 68cc. $150
3. Mostly complete big block Oldsmobile cylinder heads coded G, 80cc. $200
4. Cast iron 4-barrel spread-bore Pontiac intake manifold date coded K177 - November 1967. $100
5. Edelbock Performer Intake Manifold Pontiac, complete with block-off plate and plugs. $100
6. Edelbrock Performer Intake Manifold Pontiac, bare, doesn't appear to have ever been used. $125
7. Small block Oldsmobile OEM aluminum intake manifold. Coded A5, from a late 80's 307. $20
8. Holley Carburetor. Came from 455 Oldsmobile powered Jet-boat. $100
9. Pontiac Flex Plate, possibly from a '79 301. $20
10. Mostly complete Pontiac 4x cylinder heads date coded E024 and D304 - April and May of 1974. 2.11 Int. 1.66 Exh. 118cc. Great for a turbo or blower setup. $250
11. 1979 Pontiac Trans Am Automatic shifter and shifter plate. Shifter in good condition, plate damaged. $50
12. 1979 Pontiac Trans Am Rear window trim R&L. Painted black, not in bad shape. $20
13. 2 sets of Corbeau Seat Sliders. Used but in good condition. Great option for getting custom seats to fit. $60
14. 1979 Pontiac Trans Am transmission crossmember for TH350. $50
15. 1979 Pontiac Trans Am brake booster, master and proportioning valve set, front discs, rear drums $75
16. 1979 Pontiac Trans Am headliner trim front and rear (metal pieces) in Carmine red, good condition. $20
17. 1979 Pontiac Trans Am headline trim right and left (plastic t pieces) in Camel, good condition. $20
18. 1979 Pontiac Trans Am AC box, complete, good condition. $80
19. 1979 Pontiac Trans Am AC box side, good condition. $8
20. 1974 Pontiac TH400 3-speed Automatic transmission, short shaft, coded P-R-16606. Condition unknown. $200
21. 1979 Pontiac Trans Am drivers side door sill plate, driver quality. $5
22. 1979 Pontiac Trans Am rear speaker grill, Camel, great condition, hardware included. $10
23. 1979 Pontiac Trans Am hood release cable, used, driver quality. $10
More items to come. I have plenty of pictures if you need anything not shown.
Send a PM, post an offer or email me directly at [email protected]
Thanks for looking!
'75 Olds 350, Muncie M21, 3.23 Posi
Old 06-12-2011, 08:34 PM
birdsandgoats birdsandgoats is offline
Pm sent
Old 06-12-2011, 09:01 PM
chris66's Avatar
chris66 chris66 is offline
Pm sent
Old 06-13-2011, 06:35 AM
79Poncho's Avatar
Forgot to mention that shipping is not included in the listed prices. I will be happy to ship anywhere and will get shipping quotes as soon as I receive interest in a particular part.
Thanks.
Old 06-23-2011, 06:56 AM
79Poncho's Avatar
4-77 Pontiac cylinder heads boxed up and shipping today, thanks PY!
Also, I will be able to deliver any and all parts to Trans Am Nationals in Dayton or anywhere along I-75 between Lexington, KY and Dayton, OH that weekend.
More items and pictures coming this weekend, including '79 Front Subframe and '70 Oldsmobile 350 complete carb to pan
Thanks for looking!
Old 06-26-2011, 09:28 PM
79Poncho's Avatar
Round II:
Assorted gaskets for Pontiac and Oldsmobiles $30 takes it all
Pontiac valve covers, painted ready to install with breather (not shown) $60
1979 Pontiac automatic shifter knob, button and retainer ring great condition $30
Pontiac water neck $5
Mr. Gasket carburetor adapter PN 1932 $10
Oldsmobile Choke tube $5
Pontiac 400-4V Chrome Air cleaner $10
Stewart Warner Hour gauge, NIB (old but unused) PN 15002 $30
Pontiac chrome low-profile water neck $10
Pontiac screw-in rocker studs, used $10
Pontiac valve covers with oil deflectors PN 490027 $30
Sunpro analog boost gauge $5
Sunpro analog volt gauge $5
Pertronix Flame Thrower Coil $30
1979 Pontiac Trans Am brake sensor $2
1979 Pontiac Trans Am spare tire hold-down nut $1
1979 Pontiac Trans Am door jamb sensors (set) $2
1979 Pontiac Trans Am 301 Carburetor base air T-fitting $2
1979 Pontiac Trans Am Air Vent Director $5
1979 Pontiac Trans Am seat track/bolt cover $2
Pontiac oil filter housing w/pressure sensor $20
Random air duct (no idea, but it looks like you can use it...) $5
Pontiac oil filter housing with pressure sensor $20
Melling oil pump used PN 54-D $5
Rochester 2-Jet Code 7011834 $40
1979 Pontiac Trans Am center console lid, good condition $20
Pontiac 2-barrel intake manifold and matching Rochester 2-jet, complete carb coded 7037601, manifold date coded G188 - July 18th 1968 $100
1959 Ford Shop Manual (?!?!? I figured it be thicker!) $10
1979 Pontiac Trans Am Hood popped from reinforcement but not bad $40
1979 Pontiac Trans Am front subframe $150
1979 Pontiac Trans Am rear interior seat panels, camel, need work $20
1979 Pontiac Trans Am tilt, cruise steering column, complete carmine red, $125
1979 Pontiac Trans Am standard interior door panels in camel, 6" speaker cutouts $40
1976 - 1978 Front turn signal lights, set $10
1979 Pontiac Trans am battery tray, good repairable condition $5
1979 Pontiac Trans Am gas door spring $5
1979 Pontiac Trans Am cruise control unit with cables $40
1979 Pontiac Trans Am side view mirror set, missing DS mirror, $30
1979 Pontiac Trans Am arrowhead center caps for rally IIs, $5 for both
1979 Pontiac Trans Am interior wire harness, cut $5
1979 Pontiac Trans Am HVAC controller with wiring/tubing $20
Pontiac / Oldsmobile automatic flexplate cover $5
1979 Pontiac Trans Am radio face plate $10
1979 Pontiac Trans Am automatic shifter base plate $5
1979 Pontiac Trans Am center console boxes $10 each
1979 Pontiac Trans Am DR sun visor, carmine red, $10
1979 Pontiac Trans Am rear seat belt, female, camel $5
1970 Oldsmobile 315hp 350c.i. engine, complete with rebuilt 4 barrel quadrajet, block code: 385558, #6 heads $750
All prices do not include shipping and are OBO. I can bring any and all to TA Nats in August if necessary.
Thanks for looking and feel free to make me an offer!
(pics coming tomorrow)
Old 06-27-2011, 07:11 AM
79Poncho's Avatar
Originally Posted by 79Poncho View Post
Round II:
More pics coming tonight, sorry they're coming in bunches, internet broke during my upload to photobucket...
Old 06-27-2011, 06:38 PM
79Poncho's Avatar
More coming soon
Old 06-27-2011, 06:59 PM
79Poncho's Avatar
JVC Head Unit & Jensen Speaker Set $20
Sunpro Drag'n Tach $10
Pontiac Power Steering Pump $30
Pontiac Timing Chain Cover & Water Pump Assembly $60
Pontiac Cast Impeller Water Pump $20
Heater Blower Motor $20
1979 Pontiac Trans Am 1.25" Front Sway Bar $50
1979 Pontiac Trans Am Front Suspension Complete $150
1979 Pontiac Trans Am Glove Box Insert $10
1979 Pontiac Trans Am RH Grill $40
"7a" Small Block Oldsmobile Cylinder Heads $100
1979 Pontiac Trans Am Interior Sail Panel $40
1979 Pontiac Trans Am Std. Seats in Camel $50
Old 06-28-2011, 08:24 PM
79Poncho's Avatar
I remember reading in the wanted section that someone was looking for one of these... I have another but its stubborn coming off the seat... $5 plus the ride.
Old 07-07-2011, 04:17 PM
Pepi's Avatar
Pepi Pepi is offline
PM sent
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 07-28-2011, 07:03 AM
79Poncho's Avatar
All, if you need something and don't see it listed please ask. I may have it but haven't gotten around to taking a picture and posting it for sale. All prices are negotiable too. Remember, free delivery to TA Nationals!
