I was all set to put my reconditioned #96 heads on my used 73 400. I was planning on installing a Comp XE 262 cam. Everything else on engine will be stock. I got a good deal on rebuilding my original 455 bottom end. My buddy checked out the block and says all looks good. My question- will the XE262 still work well in the 455? I'm looking for good bottom end and a nice sound. Car will never go over 5 grand. Thanks for any help or suggestions.
73 Grand Am 455 Muncie M20 4 speed 3.23 gears |
That would be a good pick for power under 5k in a 455, you should be able to idle it at 750 and the cam`s lift will work with the stock valve train height and springs.
You still running stock springs on those heads with the oil shields? If so, I wouldn`t run that XE262 cam. 470 lift is pushing it and, the XE series is too agressive, to me, for stock springs. Also, I don`t like that cam in a 455. Too short a seat timing and with the `96 heads, will prolly be a detonation machine.
yes, I'm running stock springs. Which cam would you suggest? What about a 068 cam? This was my second choice. I also did a search and see the Summit 2802 works well in the 455 with #96 heads.
73 Grand Am 455 Muncie M20 4 speed 3.23 gears Last edited by pete315; 07-06-2011 at 08:19 PM. |
I'd probably put a Crower #60243 cam and some #68404-16 springs in it and let it eat.
But that's just me... JM2¢ Bret P. |
I`m with Bret. You need to ditch the stock springs/shields. I was gonna pick the Crower 60916 or the 60242. But depending on how much "sound" you want, the 60243 that Screaming stated will work.
Also, when stepping up to the 60243, I would run headers instead of manifolds.
Insist on keeping the stock springs?
If so then I'd run a stock cam like the 068. If you are willing to upgrade the springs and are still keeping the stock log manifolds I would choose the Summit 2802, the Crower 60916 or 60242 (60916 & 60242 are nearly identical). |
Ran the XE262 Cam in a 9.5 to 1 455 with Q-Jet and Performer intake and 1 inch 4 hole spacer. Awesome throttle response and nice rumble at idle FWIW Rich
did you use stock springs?
Piss poor choice for a 455 with very much compression in it, IMHO. Might be OK for a 7.7 to 1 CR 455 with some 7M5's or bathtub chamber 4X heads, but you are going to leave a BUTT LOAD of power on the table putting a tiny cam like that in a 455 with 9.5 to 1 compression and decent flowing heads on it.....Cliff
now I'm real confused. I have no idea which cam to get. I am running stock valve springs, stock intake and exhaust manifolds.
Read my post above again.
The stock springs, especially used ones, pretty much dictate a low-lift mild cam. The 068 cam is the biggest one I'd consider using. Personally I wouldn't hesitate to change the springs, it's easily done with the heads off the engine since you're swapping them onto the 455. Then you can run one of the bigger cams that will still run quite well with the stock intake and exhaust manifolds. |
Karl
I did have new Springs put on the heads ( 7C2 ) I believe. Had the Intake Valve Upgraded to 2.11 and screw in studs installed. This Cam went in 1974 5100 pound 4 door Grandville with 105,00 miles on the original bottom end and pushed that tank to 14.0-14.1 at 97 MPH in 1/4 mile. Pulled great to 4800-5000 Rpm
If you are installing #96 heads on a 455, it will have enough compression to easily manage 224/234/112 sized cams and delivery a smooth idle, great street manners, and broad power curve.
If it's a budget build, get a Summit 2802 cam. It'll make good power to near 5000rpm's, and be pretty user friendly on currently available pump fuel as well. I have two carb customers in the files who bought engines with around 9.5 to 1 compression with the XE262 cam in them, that absolutely HATE them at every level. I have another customer who opted for the XE268 cam and ended up with a "turd" for 455 street/strip engine. His car should be running high 11's/low 12's, and he's BARELY in the 12's with it in good air. The owners of 455's with the XE262 cams both claim the idle is "quirky", extremely octane sensitive, and piss-poor power production at every level. One of the engines was "professionally" built by a shop who caters to Pontiac engines, where they were promised strong power to 5500rpm's and great street manners. The owner of that engine is about ready to take a long drive on a short pier with his pride and joy!.....Cliff
Thanks for the info Cliff. Guess I'll stay away from the XE262 and go with the Summit. I'm going down today to pick up the heads. I know I had new stock springs put in. Do you think the Summit 2801 would be too small?
One needs to know how cubic inches and compression affect which "size" of a cam he chooses. Any cam will "act smaller" in a larger engine. So, what`s good for a 350 or 400 can be too small for a 455. One needs to choose a cam to get the results he wants for his CID, then he needs to make sure it will "fit" in his engine. If the valve will only open so far before it bottoms out on the head or hits a piston, one needs to create enough space to accomodate such a cam. Also, cams need a spring PRESSURE to go along,or you will "float" the valves. So, when buying a cam, check for spring pressure, coil bind, piston to valve clearance, and retainer to guide clearance at a minimum. The larger the cam, the more important. This might help. http://www.fortunecity.com/silversto...build/cams.htm |
I'd go with the larger cam. A 2801 works very good in a 400 engine around 9.5 to 1 compression, the larger 455 at the same compression ratio will like about 10 degrees more duration.
We also have to keep in mind here that a larger cam tends to make the engine more pump gas friendly. FWIW, if I were building the same engine here, it would get a RAIV sized cam, a set of Rhoad's lifters, and high ratio rockers. I'd also be tempted to put one of Ace's Wolverine 5059 clones in it, but since we quit using flat cams here quite some time ago, we haven't tried any of the newer offerings. I'd also cut the heads just a tad and put the compression closer to 10 to 1......Cliff
Interesting, a larger cam will make car more pump gas friendly. I'm going with the 2802. Thanks to everyone for their advise. I'll let you guys know the results when I get it running.
