Originally Posted by weevilkenevil
the champs right ,those wheels are "metric" cause there off aussie made commodores and although there on and bolted down the studs will not be exactly central in the rim ,id be getting them off before a good pothole does it for you !
as much as i appreciate the concern, .325mm different per stud in minimal at best. i wouldn't be suprised to see that much difference in several wheels out there. if any thing, the back spacing is more of a concern to me than the bolt pattern. i'm not real fond of spacers even those that are hub centric. so as of right now, i just don't have full turn lock to lock. might be missing a half turn in either direction, so not to bad. but thanks for looking out for a classic pontiac.
