Old 08-29-2011, 03:38 PM
RedDirtRoad RedDirtRoad is offline
Don,
You are 100% correct
I have a few things I have done to the car thats not original but did so anyway just for better handling and driving.
The sway bar is from a later Pontiac. I also have a Trans am steering box and front sway bar too. I rather it handle best it can and lose judging points.
I welcome all criticism from others too..I like hearing feedback how my restoration can be better
Old 09-03-2011, 01:38 PM
ChuckG's Avatar
ChuckG ChuckG is offline
I believe that this is the power steering cap you were looking for:
http://cgi.ebay.com/ebaymotors/_W0QQ...T#ht_707wt_941
I bought one from this place last month and really like it.
Chuck
Old 09-03-2011, 01:52 PM
Thanks Chuck,
I already bought the correct P/S cap, the correct breather with the dimples too.
I now have the car on the frame, Factort A/C installed and working on the firewall and dash board and instruments.
Old 09-04-2011, 01:21 PM
ctgross ctgross is offline
I think I finally figured out the pic file from that 66 at the car show.....so here goes??
ID:	255480   Click image for larger version
ID:	255481   Click image for larger version
ID:	255482   Click image for larger version
CT Gross---66 GTO
"Its never too late to have a happy childhood"!
I told my dad I was going to stop raising hell, and he called me a quitter!
Old 09-04-2011, 01:36 PM
and a couple more(mine is the blue car) and the last pic is with him, he's a retired capt. with the Arkansas State Police.
ID:	255484   Click image for larger version
ID:	255486   Click image for larger version
ID:	255487   Click image for larger version
CT Gross---66 GTO
Old 10-31-2011, 08:26 AM
Default Making Progress
I installed the A/C heater box, dash board, instruments, wipers and brake booster and lines.
Did alot more work over the weekend and will post more photos tomorrow
ID:	261680   Click image for larger version
ID:	261681   Click image for larger version
Old 10-31-2011, 10:17 AM
SD421's Avatar
SD421 SD421 is offline
Looking GOOD!!
If I might make a suggestion. Put something over the top of the carb so nothing falls down inside.
Don
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
