Old 08-29-2011, 08:28 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Originally Posted by BruceWilkie View Post
Good to see progress.
BTW a diode will prevent feedback. My Accel box was getting feed via the altenator and kept motor running even though voltage dropped to 3 volts. I had originally used a relay figuring that would kill power to ignition and pump and the feed back was sufficient to keep it energized as well. Cut the switch... motor "coughed" and "switched back on. I unplugged power feed from fuse. Tried just a switch and thats when I found I had feedback.
For the test run without a alternator, I wasnt expecting to get that much feedback from the ignition box. When you dont want the motor running, 30 seconds seems like a lifetime. I'll just keep the wires seprated by a toggle switch for now.
