Old 09-01-2011, 11:12 AM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
I would like to see those photos for sure.
To the best of my knowledge, and this applies to the rear end only for 65-66(and maybe up to 1970?) B-body Pontiac, I've come up with this....
To perfectly CENTER the wheel in the wheel opening between frame and quarter lip (which may require trimming with the wider rims anyway):
A 6" rim must have 4.375" (111mm) backspacing.
A 7" rim must have 4.875" (124mm) backspacing.
Obviously 6 and 7" rims need not be perfectly centered due to being so narrow already.
But centering is critical as we go wider....
A 8" rim must have 5.375" (136mm) backspacing.
This is exactly what I have right now on my 65GP, the rims modified by Stockton. Very tight fit with 285/70 tires...had to roll the quarter lip up. Don't run fender skirts anymore, too painful to deal with.
A 9" rim must have 5.875" (149mm) backspacing.
A 9.5" rim must have 6.125" (155mm) backspacing.
A 10" rim must have 6.375" (162mm) backspacing.
So while all these rims widths change, the thing they have in common (for perfect centering) is their "offset"....it always stays at 22mm, about .9". You can verify that on that tire sizer site... http://www.rimsntires.com/specs.jsp
I see on Ebay Motors that for at least the MB 17 x 9.5" wheels, they tend to have a 6mm offset, that is just not enough..with the factory drum brake 65.50" wide rearend, it's won't allow your wheel\tires to be centered between frame and quarter lip...pushing them over half an inch closer to the quarter lip, and away from the frame.
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
Old 07-25-2014, 10:21 AM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Based on this great info above. I have been thinking of a cheap 15x8 steel wheel for 28x9x15 MT slicks for the 67 Cat 2+2 , Wheel Vintiques has a Chevy Ralley 5x5 in 15x8 with a 5.0 BS so not quite 5.375 BS but I would be rolling the lip in anyway. Stil a bit worried of rubbing, I know Milt runs this size slick on his 66 with a 15X8 ? 8 lug wheel but he still runs skirt and I will not be. Also need to check the 15x7 and 15x8 Silverado Rally and see what the BS is , is the 15x7 around 4.5 or 4.0 BS ?
63 Catalina coupe 467 cid budget drag car low 11's 1/4 , 7.0's 1/8th pump gas n/a
66 Star Chief Executive 59k mile 389
67 IH Scout project 2WD "Indian Scout"
69 Le Mans 2 dr HT 350 91k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 108k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2008 Saab 9-3 2.0T convertible
Old 10-28-2014, 07:55 PM
ChiefPonch ChiefPonch is offline
20x8.5 with 265/35's on the rear.
18x8 with 245/40's on the front.
About 1/4" of clearance in the back between the tire and quarter lip & same on the front when the wheel is fully turned. I believe the offset is either 0 or +2mm on both front and rear.
