Call me crazy and cynical, but I didn't believe they would do anything about the problem. Still don't. I'll believe it when I see it.
George
typical management B.S. diehards go ahead and wait for cardone! but like i said before why wait for Cardone!!!!!! the Flowkooler pump is working out very well and is a quality pump with the cast impeller everyone rants about!!!
mike |
Thanks |
mike |
It's cooler outside now, which helps, but I'm determined to improve my '66 temps before next summer. If Cardone comes through, I'll put in their "correct" impeller 8-bolt and use my old divider plates (unless someone makes correct contoured new plates by then).
If they don't, what do people recommend fits better with the Flowkooler pump...old plates, new SS plates? If the latter, who has replacement plates that work with it, do they require hammering, how well will the contour mate to the Flowkooer impeller, etc? If the old plates, will they require tweaking on contour for the Flowkooler? Or, does anyone recommend another option? |
peahrens
the adjustment is easy i had to actually tweek it outword a little! never tried to adj. with the original plates. if the F/K pump works as good for you as good as it has for me who cares about cardones correct impeller which in any case you will still have to adjust the internal housing plate, reason being each impeller will set different on the shaft!!! mike |
