Old 10-26-2011, 07:30 PM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
A Pontiac distributor will sit in the block anywhere you want it to. The only thing that dictates where it sits is how the cam gear meshes with the dist gear and what position the oil pump shaft is in when the dist is dropped in. It's not keyed in anyway. You can manipulate the oil pump shaft with a flat screwdriver so the button will face where you need it to. With that said, as stated before a Pontiac fires at either straight up or 180* out as both #1 and #7 cylinder are at TDC at the same time. When you turn the balancer so the timing mark is at 0 you are firing on #1. The button should be at roughly 1 o'clock. As I stated before, the distributor itself will drop in anywhere. You can turn the oil pump shaft so it is turned so it will mate up with the dist gear. Make sure your vac advance won't hit the intake manifold. I've had this argument with many people. I do it all the time.
_____________________________
www.classicpontiacrescue.com
Old 10-26-2011, 08:35 PM
cnc's Avatar
cnc cnc is offline
Think u meant #1 and #6 at TDC the same time...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 10-27-2011, 03:08 PM
You are correct sir! That's what I get for trying to explain something so soon after dinner lol..
Old 01-21-2012, 10:41 AM
FrankieT/A's Avatar
When you line up the mark on the balancer to TDC it has to be on the compression stroke for number one cylinder
Old 02-17-2012, 01:10 AM
rockin78T/A's Avatar
rockin78T/A rockin78T/A is offline
I moved the distribtor. Car has been fine until it got cold here. Had to charge the battery, ran great after the battery charged. Tried to Start her after a week of sitting, no fire. Instead of pulling the module again, I just wiggled around the wires tha connect to the module, put the cap back on, fired right up. So all this time, it seems to be a connection problem, but why does the car not die when driving it?
God didn't give you a belly just to hang a button on it!
