My 10th TA is having a problem with I guess the power window circuit. It affects my Tach, fuel gauge, key buzzer and power windows. The tach will peg out, or freeze, and the power windows, and fuel gauge stop working, and perhaps the voltmeter. I had this problem for quite awhile. I once put my foot up where the fuse box is, and my foot touched the wiring, and everything started working again.It now quit working again. I now look under there and try wiggling stuff, and the tach will peg and get stuck, and the door key buzzer will start buzzing, but I can't get it to work again. Any ideas on the best way to diagnose and fix this problem? Could it be a bad fuse box, the wiring behind it, or something else?
Thanks |
Sounds like you might have chafed wires or a grounding issue. I would trace the wires of the Tach, Pwr windows, fuel gauge, and voltmeter and see if there might be cuts or breakes in the wiring. Look at your ground on the back of your instrument panel to see if it is loose. I by no means am an electrician. I'm sure that someone who is will jump in shortly.
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
the is a bolt that holds the two parts of the fuse block together. check to see if that bolt is loose. I think the bolt is on the front side.
Its ok to giggle and snicker, Dont laugh and point |
Has this car ever had work done to it that would need the under hood harness removed???
If so, Ollies idea would make even more sense .
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down...
Thanks for the ideas. I will check that bolt.
FWIW: I had a similar problem in the early 80’s with the 1st 78 TA I owned.
Car was all original, 400 Auto, Pwr Windows, Cruise, with factory wiring harness. It ran flawlessly for years and suddenly –one day - the electrical system gremlins said hello. Symptoms: At a standstill with the Tach pegging, Gauges inop, etc. at engine start up, once or twice, just like yours. Then after turning the engine on and off, it returned to normal operation. A few days later while driving on the interstate, same thing happened; Tach pegged, gauges inop, etc. then back to normal. The engine never missed a beat, continued to run fine. I realized that this was occurring as I was driving over a gradual up and down section on the road way. Once I got to my destination, opened the hood looking for the obvious…and nothing! At first. Then… I got lucky: After feeling around the engine wiring harnesses with my hands for any “Hot to the touch” electrical wiring, I discovered that the positive battery cable was very hot to the touch, and there was a slight smell of burnt insulation. With the key in the on position I would get the same gauge problems. The alarm screeching on my radar detector plugged into the cig lighter made the diagnosis easier from outside the car. Conclusion: The positive battery cables insulation was laying on the sharp edge of the upper control arm and had rubbed a hole through the insulation of the positive battery cable. The cable was an aftermarket replacement, which was longer than the original. Each and every time the suspension flexed, the control arm moved and the positive cable would go to direct ground and cause the same problems you experienced. Hope this helps you. I suggest you keep it simple, and look for the suggestions posted earlier, such as bad grounds, etc. No doubt there will be other “experts” here who will tell you what is really wrong with your car! LOL!!!! Another simple ground problem: The only other electrical issue I had was when the dome light switch on the drivers’ side got slightly corroded on the threaded ground where the switch screws into the door jamb. This is a single wire positive wire switch grounded to the body. When parked on an incline, passenger side lower than the driver side, the dome light would come on with a dim brightness (due to bad ground and body flexed on the incline allowed slight movement of the drivers’ door). Simple Fix: Removed switch (drivers side was problem), wire brushed and cleaned threads on switch and door jamb ground threads. Once clean, I used di-electric grease on the switch threads and door jamb. Problem solved. |
Thanks for the ideas Alvin. I will take all this advice when I get a chance.
In the mean time, have a Happy Thanksgiving. |
