Pontiac Business Entities Exchange Sources, Compliments and Grievances in regard to Pontiac parts or services rendered by an individual or business.
Old 11-24-2011, 12:03 AM
arrowem's Avatar
arrowem arrowem is offline
Default Parts Place RAIV intake.
Ooops, I posted this in the PY section before, I think here is a better place for this
Well I got one and had it shipped "sight unseen" to Dave at SD Performance to do the "Cliff intake Works", and remove the water crossover. Here is what he had to say-
Hi Jason
Well you have the best repop HO intake I've ever seen.
I was able to run the whole program with no welding!!!
A couple corners are a bit close but I don't see any issue with them sealing.
If I remember correctly you'll need to make sure one of the bolt bosses has a bolt in it as it blew into a runner. I was going to put a bolt in it but forgot. It's no big deal, just put a bit of thread sealant on a bolt or put a set screw in to seal the whole. We have this happen on lots of different intakes. It was a bit more hand work to get things lined up but I was pretty pleased with the end results.
The intake was shipped last Thursday so you should see it this week.
I love it!
ID:	264654   Click image for larger version
ID:	264655   Click image for larger version
ID:	264656   Click image for larger version
'68 Firebird
-Before you press that thing to the floor, be sure you're right with God....
'68 hard blocked forged 463 (thanks Luhn Performance), SD prepped HO aluminum intake, SD Perf 290cfm KRE'S,'Ol Faithful cam, 2004r with a "Jim Hand special" converter to a 3.42 Trutrac 12 bolt hung from a 4 link. With a 120 shot of N2O for fun.
Smilies are Off
