Old 11-26-2011, 11:50 PM
anewtoi's Avatar
anewtoi anewtoi is offline
more photos of dash and column
ID:	264950   Click image for larger version
ID:	264951   Click image for larger version
ID:	264953   Click image for larger version
ID:	264954   Click image for larger version
Old 11-27-2011, 09:38 AM
2002Z4CSS's Avatar
At least your car was not finished when you painted this. Clean rags and thinner and it will be ready for paint again. You may actually get a decent finish from a rattle can if you overlap the paint.
1971 Pontiac GT-37
Old 11-27-2011, 10:26 AM
timemachine timemachine is offline
Just went through the same thing on my 68 lemans!
Started doing an auto to 4-sp swap-one thing led to another.
The first shot at painting the dash fisheyed big time everywhere.
Had to resand ,prime and paint again.Ah the fun
Old 11-27-2011, 11:49 AM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
But how many enduras do you need?
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 11-27-2011, 12:11 PM
anewtoi's Avatar
HAHA, very astute observation. i actually thought i was getting a great deal on a straight bumper, a slightly unstraight one and a hood for under $500. the hood and work i put into has already offset the once-great deal.
Old 11-27-2011, 04:18 PM
anewtoi's Avatar
test fitting the dash bezel. not looking good so far. first off, I had to shave off 1/2" from the right end to clear the glove box. then I had to shave about 1/4" x 1" from the far right top corner to clear the hinge(top right of the radio) thats for the dash pad. next step is to mount 3 mount tabs for the top mounts that go under the dash pad. and some type of receptacle for the lower mounting tabs. theres 2 need to be placed. too much work for something that supposedly "fit just like the original"
ID:	265068   Click image for larger version
ID:	265069   Click image for larger version
ID:	265070   Click image for larger version
ID:	265071   Click image for larger version
Old 11-29-2011, 01:05 AM
anewtoi's Avatar
sooooo, after an hour of running between harbor freight, lowes, and advance auto, about 30 bucks for more hook and loop pads, acetone, t-shirt rags, another head for my multitool (that didnt fit BTW),and about 3 hours of sanding with the multi-tool and 80 grit, I finally realized that my handy dandy 18v dewalt and a wire bristle attachment works muuuuuccchhhh better than the multitool at stripping big chunks of paint at a time. another hour with the drill, 20 min ace scrubbing, 20 more minutes finishing with 80 grit and 220 grit. finally ready for primer. GOOD GOOGLY MOOGLY!! DID EVERY ONE HAVE TO LEARN THE HARD WAY OR JUST ME.
Old 11-29-2011, 01:46 AM
anewtoi's Avatar
btw, i decided to try some dupli color acrylic laquer gloss black for the bottom section of the dash. has anyone tried this? whats been your experience. any other paint suggestions to get the factory look?
Old 11-29-2011, 08:53 PM
I think pretty much everything I have learned has been the hard way,so with you on that one.
The original black was low gloss.I went with high gloss,i just like the look better.
After the second try I still had a couple of craters(you can see one in the closeup)SCREW IT!IT'S A DRIVER!I was not sanding the thing down again.Move on!
ID:	265303   Click image for larger version
ID:	265304   Click image for larger version
ID:	265305   Click image for larger version
ID:	265306   Click image for larger version
