do a search on rear tail light harness from 69gtocv. There is a pic in there that shows the wiring which comes out of the trunk and follows the passenger side hinge up to rear deck the pic is not the greatest but you can see it fairly well. switch in glove box has two connections one comes from your clock power lead and the other goes from switch under seats and out to trunk to release solenoid which is in the pic I'm telling you about. I think the trunk light plugs in to the harness near the driver side hinge. I hope this helps
here's the picture for you, your dotted line I think is correct
Thanks Ledbetter for the help.
Does anyone know what color the latch mechanism should be. Right now it has overspray from the original color painted on the inside of the trunklid. Should it be silver, black, ??
Thanks Dave |
trunk release to my car many years ago and when I purchased it there was no paint on the latch(it was a used assembly found in a wrecking yard by a GTO vendor) Upon installing it, I discovered that it was impossible to install the cable without the latch being out of the deck lid, so it seemed to me that since nothing had any paint on it, it must have been installed on the assembly line after the car was painted. Making this assumption, I left the latch natural as it was when I bought it, but I've often wondered if maybe the GTO parts vendor cleaned the old overspray off the latch with paint remover before I bought it. I hope someone on this forum with this option from the factory can answer this question. |
What cable are you referring to?
Sorry, wrong terminology......I was referring to the wiring harness. You
can't plug the harness in to the latch with the latch on the decklid. And you can't paint the deck lid with the wire installed as it would interfere with painting the lid where it runs out the hole above the hinge. I made the assumption that they installed a manual latch on the car to paint it, or just put a wire on it to close it while painting the top of the lid, then installed the power trunk latch and wire later on down the line. |
The '67-72 electric trunk releases for A-bodys & '69-72 GP's, being one piece solenoid & latch, will be clear zinc plated. They get washed out looking over the years, & some will have had condensation & slight rust on them, so some look much better than others. The '67, 68, & I believe all ( I hate saying all!) '69's trunk poppers had a pink wire pigtail. All the '70-72 integral trunk releases I have had & have, have the black pigtail. On 2nd Gen F-body & '73-77 A-body style, the trunk solenoid is by itself, & the latch is separate. This is the style quite a few ------ sell on eBay as "original" GTO -SS Chevelle-442. Will require mods to the trunk mtg hole area on a '68-72 A-body. The latch for this style of power trunk release is actually different between standard trunk release & power trunk release, One will need to make sure & get they correct the latch with this style many many latches were painted. I have all colors.
