Old 11-19-2011, 10:26 AM
jer119 jer119 is offline
Default Subframe repair
I have a subframe off my 67 Firebird, with 3 out of the 4 body mount holes that are rotted out larger than they are supposed to be. I was thinking of repairing these areas by cutting out the rot and welding in new plates and hole sawin' them back to the original size. Has anyone done this, and have any pics, and or advice? I was thinking this would be a more cost effective way for me to get my subframe back in shape.
Old 11-19-2011, 10:52 AM
Dr.Corvette Dr.Corvette is offline
I had to do 1 mount on my frame. Here are some pics. I ground the weld smooth and drilled the hole out. You can't tell it was repaired.
ID:	263959   Click image for larger version
ID:	263960   Click image for larger version
ID:	263961   Click image for larger version
Old 11-19-2011, 11:08 AM
That's great!! I wanted to make sure that if I went through with the fix, that I would be making the right choice. I'll grab some material soon and give it a go. Thank You!
Old 12-05-2011, 01:31 PM
So I got to work on the subframe this week and got the patches in on the front perches. Just a little grinding and they should be good. I used the other subframe to cut patches from.
Old 12-05-2011, 02:12 PM
2002Z4CSS's Avatar
That's one way to fix the rusted hole.
1971 Pontiac GT-37
Old 12-05-2011, 02:33 PM
rohrt rohrt is offline
They sell repair plates now. They are a bit pricy IMO.
I repaired mine. I made a template out of cardboard and had a metal fab shop make them for me with the holes already done. I don't remember them being very expensive. Mine take up the whole mounting space area.
Old 12-05-2011, 10:53 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Thumbs up
Ah, necessity... the mother of invention. Excellent work saving the frame!
Eric Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
Deuteronomy 8:3
Old 12-06-2011, 05:14 PM
Do you guys know the diameter of the holes? My best rear mount hole is at 1 5/8. I don't have anything to go by, but i'd like to know if the new bushings are supposed to be a snug fit through the frame. The new bushings look to be 1 1/2. A soon as I get the rear mounts done, I'll be ready to get the frame blasted.
Old 12-08-2011, 12:03 AM
goatwgn goatwgn is offline
I would make the hole 1 1/2 inches if that is what the part of the bushing that goes into it is. Use a little silicone spray installing the bushings so they go into the hole nice and smooth.
Old 12-08-2011, 11:57 AM
So here's what I ended up doing. I hope ya guys like my efforts!
Old 12-08-2011, 12:00 PM
I cut out the rear mounts off of the subframe that was on the car. that frame was in poor shape, but the mounts in the rear were in better shape than what I had on the subframe I picked up. You'll see welds around the edges, that was to strengthen them and get the holes back to the correct size.
Old 12-08-2011, 12:02 PM
Old 12-15-2011, 12:47 AM
Just some progress pics of the subframe after the repairs and sandblasting.
Old 12-15-2011, 02:30 AM
Nicely done! Looking good now...
Eric Mitten
Deuteronomy 8:3
Old 12-15-2011, 07:28 PM
I bought the repair kits in 04 when I did my wifes car. Ames or maybe Detroit speed? Anyway I felt they were worth it. Had everything done in one night.
Old 12-15-2011, 08:23 PM
bryansMtngto's Avatar
bryansMtngto bryansMtngto is offline
Default sub frame
I remember the day at The Grove that i snapped my frame and tore the rear end out of the car. Dropped it on the rear 1/4's. Thats when we decide to do a custom 2x3 chassis for the car and the fiberglass front end.Hast be 15 years since that happened.
Old 12-15-2011, 09:16 PM
2002Z4CSS's Avatar
The subframe looks like new now.
1971 Pontiac GT-37
