#341
Old 10-03-2011, 09:43 PM
mbwicz1 mbwicz1 is offline
Default 72 Lemans suspension parts
I have the front suspension (UCA, LCA, drum brakes, spindles), rear control arms (lowers have been boxed), springs (fronts minus one coil). Also have drum brake non-posi rear end. 48k mile 72 lemans, 350 2bbl with a/c.
Free for the taking, let me know what anyone wants/needs. I hate to take stuff to the scrap yard, but don't want it hanging around forever. I am in the Buffalo, NY area. I am in the process of redoing the car and have replaced suspension with aftermarket stuff.
Mike
  #342
Old 10-07-2011, 08:26 PM
Default Urethane rear suspension bushings
I have (6) rear suspension bushings, urethane from Energy Suspension. I installed aftermarket control arms and only used (2) bushings from the kit. Let me know if you want a pair or all of them.
I also have a driveshaft from a 72 lemans with a 350 turbo and 10 bolt, plus the other stuff that I listed a couple of days ago. zip is 14031.
Mike
  #343
Old 11-16-2011, 12:36 PM
gto406 gto406 is offline
I have two (qty: 2) doors (driver + passenger) for a 1972 Pontiac GTO (or Lemans Sport, Luxury Lemans, etc.). They need skins, but with some 'elbow you know what' could serve as a basis for a decent driver quality resto. Passenger door is partially stripped.
I also have the hinges for them, and the hardware. I will even throw in the old strikers and those black plastic vent 'thingys' that plug into the rear part of the door jamb. Glass is included (but one side pitted). Door mirrors NOT included.
Local pickup only, these suckers are heavy and would be a bear to ship! Located in Toronto (close to Toronto/Mississauga border).
BR/Brian.
  #344
Old 11-16-2011, 01:23 PM
marks73ta's Avatar
marks73ta marks73ta is offline
Looking to find a Dearborn 3 speed toploader trans for the GM cars. I'll pay all shipping if you have one that you're tired of stumbling over. Going to 85306.
I do have a matched pair of front bumper frame horn to bumper brackets. They are off of my 65,000 mile Arizona '63 Catalina. They need very little cleanup and paint.
This is a great thread. Thanks everyone. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
  #345
Old 12-15-2011, 11:31 PM
Brent Flynn's Avatar
Brent Flynn Brent Flynn is offline
Mike
i could use them!
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft
1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,([email protected])1.578 60' Oct 2010!!
  #346
Old 01-04-2012, 08:14 PM
indymanjoe's Avatar
brand new in the box set of .40 over piston ring kit pn E-251k 40 ,sealed power brand.I wont be needing.
I am the Thread Killer!
  #347
Old 01-04-2012, 09:23 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
I have a set of never used solid aluminum front subframe bushings for a 2nd gen F-body.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 300CFM D-ports, Howard's custom SFT, Nash Intake,QFT 950 E85 carb, TCI TH-350, 4200 converter 3.73 12 bolt [email protected]
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1972 LeMans 350 Pontiac H/S Drags project
  #348
Old 01-05-2012, 01:27 PM
firebirdcrazy1959's Avatar
firebirdcrazy1959 firebirdcrazy1959 is offline
I could use those.I'll pm my address.
1977 Trans Am,400 4 speed,numbers matching car
1979 Bonneville ,1 owner car...
1997 Trans Am convertible,LT1/auto.
  #349
Old 01-05-2012, 02:54 PM
Johnny406's Avatar
They are yours
  #350
Old 01-10-2012, 06:29 PM
Nikwho's Avatar
Nikwho Nikwho is offline
I tried to look these up. Are they +0.040" for a 455? I could use them if they are!
Nik C.
  #351
Old 01-11-2012, 09:17 PM
projectfolly projectfolly is offline
Default 69 GTO Stuff
All free to a good home. I need help cleaning out my basement to create some space for my kids to play in!
You pay the shipping cost or pick up in person.
Rally Clock - Never had it hooked up to see if it works. Assume it doesnt. Looks like it has '69 date code on the back.
Brake Pedal Support Bracket - Nice condition
Original Hideaway Headlamp Covers - The mounting tabs are broken/cracked. I cant bring myself to throw them away, maybe someone could take the time to fix them. Includes repair brace.
Fuel Level Sender - Used a few summers. Works good but I replaced it during the temporary insanity of the restoration project.
Name:	rally  clock1.jpg
ID:	270405   Click image for larger version
Name:	pedal bracket1.jpg
ID:	270406   Click image for larger version
Name:	hideaway doors.jpg
ID:	270407   Click image for larger version
Name:	fuel level sender.jpg
  #352
Old 01-11-2012, 10:54 PM
indymanjoe's Avatar
Nik C.
should be for a 400cu..# on box is E-251k 40....
  #353
Old 01-12-2012, 12:17 PM
I'll take the Rally clock. PM'd you.
Old 01-12-2012, 08:00 PM
Greg - PM returned.
  #355
Old 01-14-2012, 02:56 AM
gregneun gregneun is offline
Default main bearings ACL 5M2496P-30 For 389/400/350
I'll jump in here. Got these and didn't need the end play correction that these have, never used. My machinist said the bearings would have had to go to the crank grinder along with the crankshaft. Tazmanian and not chinese! 10 bucks should ship them to any of the lower 48 states. For 30 undersized mains.
ACL Duraglide 780 5M2496P-30 Main Bearing set. CAUTION This main bearing set contains flanged thrust bearings manufactured with increased overall widths for undersize crank journals. Part numer 71049 is dimensioned in accordance with factory specifications as follows:-
Overall width increase in width
(Nominal)
Std size shaft 1.136" 28.85 mm Std
30 U/S shaft 1.146" 29.10 mm +0.010"/0.2525mm
better PM me, I'll forget about this,
Greg
  #356
Old 01-14-2012, 03:01 AM
Default in need of
among other things,
The pushbutton for a floor shifter, automatic, console 1966/1967, Tempest, LeMans, GTO.
Please PM on this as I am likely to forget.
Greg
  #357
Old 01-14-2012, 01:46 PM
Turns out Greg needed a clock for a '68 so the clock is still up for grabs..
  #358
Old 01-30-2012, 05:13 PM
blue bayou blue bayou is offline
Folly I'll take the rally clock and the hideaways.
I'll have to look and see what I have to offer up!
JD
  #359
Old 01-31-2012, 09:41 AM
rickw rickw is offline
Default Need a pair of 6x heads.... Dallas area
OK, I am seriously broke, been selling off everything but the kids lately, but I WANT to finish the 75 Grand Am project in the garage. Currently has 7m5 heads with a total of 6 broken bolts (I only did one)... need some 6x I can bolt on the 455 and go. I have a budget left of about $100, or can trade parts I have (69 GTO hood, 68 GTO fenders, 70 Hood tach, other 68/69 GTO parts, 73-75 GTO/GA parts, 77 Can Am parts).
Any help is appreciated. I've been in a 2 year running legal battle with ex, I'm just worn out, I have 2 of my 3 kids living with me, 1 income, lots of bills... you've heard it before I'm sure...
  #360
Old 02-12-2012, 06:24 PM
moparcolt's Avatar
moparcolt moparcolt is offline
I have a few things, FREE, pick up or you pay the shipping and its yours.
I have a 68 or 69, 428 Block. It is bored .030 and the bores are nice. sold the pistons, rods, and crank. My machinist said the line bore is .005 to big, might need a special length chain after re-hone. I don't want to mess with it, so who ever wants it can have it.
also a stock 455 crank, needs turned, has been balanced, looks like for a real light set of rods and pistons. It will need turned. not sure if it is standard or 10-10 now but if you think you can use it, its yours.
and lastly a factory 455 Nodular crank that was offset ground to 4.25 stroke and has 2.20 Big Block Chevy size rod pins. Might need turned but its free
All items available for pick up in Huntsburg Ohio, 44046
Just north of state route 322
Or will ship if you pay the Fed Ex
Chris
Chris Collier
1969 firebird, pro touring build. Full Global West suspension 474 Stroker with Molnar Crank and Rods, DCI Ram Air 5 Top end, Holley fuel injection, Vince Janis 200-4R trans
"There is no such thing as too much horsepower"
