By design some cam/lifter combo's make it very difficult, if not near impossible to get oil to all the rocker arms simply by running the drill and turning the engine a few times.
I've ran into this more in recent years as we are using more custom cam profiles with smaller base circles, custom flat solid set-ups, and retrofitting to hydraulic and solid roller stuff. It's not really a big deal, as long as you make sure the oil band on the lifters is correctly located during engine assembly. Many lifters are also metered, as I found out when using the Crower HIPPO lifters for the first time. We gave up trying to get oil to the rockers first time we used them, but they do a fine job in actual use of controlling oil to the top of the engine. +1 on assembly lube, if you are going to wash it all into the pan with the drill anyhow.....Cliff
UPDATE:
Went down last night committed to running the drill for 10 minutes. After about 3, oil came out of 2 cylinders. Rotated the crank 90 degrees a few turns and several more minutes of turning, I had of out of each lifter. ![]() Looks like i just needed a little more patience. Thanks for all the help |
My 470/409 took forever to get it to the top on every one and I even used an old distributor to seal the passges or Chevies won't get it to the top. I think it was like Cliff mentioned where the oil bands of the lifters were.
On my Pontiacs I usually do it with teh valley pan off to see if there are any leaks around the lifters. My old 72 HO block did for a flat tappet around where the holes were tapped for lifter restrictors. Had to go taller rollers on that block.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
