Ron with all the problems/errors I had when I took it out last year I didn't pay much attention to the flash. Was surprised I had to shift into 2nd so fast. I have a crane shift light with the bells and whistles I'm going to install this winter. It has a play back that is supposed to show all shifts but it looks cumbersome to use
Can you confirm the size of the fuel line from the tank? Is the tank sumped or are you running a cell?
-6an is small IMO for where you are.
68 Firebird Are you running with the wind or breaking it? |
Put it in myself. 5 gal sumped fuel cell, about 1' of 8an to Mallory 140 filter, Aeroquip push lock 6an to Mallory 140 pump, to Mallory bypass regulator. 2 6an off reg to carbs. And I have an 8an return line dumping into the top of the cell. Also using 8an for fc vent. I was watching the fp and rpm at the top end and pressure was around 6#s. Running 72s in carbs.
Need bigger supply line from tank to regulator running dual quads...IMO..
I run dual modified 750 Comp.AFB's on a Wenzler TR myself. Have # 10 to pump & then to regulator. From regulator I use two #6 lines to carbs...one to each. I want to go a #12 from cell to pump... I would go at least a #8 from pump to regulator... Not to say you don't have a converter issue too...
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Well I do have enough 10an to rerun both lines and it wouldn't be a problem as I had to drop the lines to install the cage but I didn't think I was there yet. If I have a fuel issue could it be caused by the angle of the motor. Since I lowered the back of the car the motor sits on more of an angle than I would like with the Wenzler or Victor. Back was so high I couldn't recline my seat enough to see traffic lights. Had to drop the bowl fuel level a fair bit as I set the motor angle with a SD intake on it which compensates for the motor angle. Guess I grasping
Definitely run a bigger line to the regulator. You won't need to increase the return line. You may have pressure, but the volume is most likely not enough.
Talk to a converter company and give them your specs. Personally, Continental has been right on for me with 3 different changes over the years. PTC, ATI have been well recommended here. I think Continental will come in a bit less overall cost wise and will deliver.
Thanks Ron, I have sent in my specs to ati. That treemaster mtr looks like a lot of converter for the buck. Will also send Cont. the specs too to see what they come up with. Have a TB I haven't used yet but once I get the appropriate conv. I may give it a try. I have talked with Coan but they are leaning to a 4200 stall.
Alan |
What am I missing as the fuel system appears ok to me? Thanks, Alan |
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
Good advice JD.
http://forums.maxperformanceinc.com/...d.php?t=681346
Here is a couple converters for good prices that might be an option.
