Old 10-25-2011, 07:29 PM
ERIC AULL ERIC AULL is offline
67 GTO Type A....
Old 11-01-2011, 08:45 PM
Pontiacmatt's Avatar
Pontiacmatt Pontiacmatt is offline
Default Lighter
My 69 GTO has the "B" lighter. I had scrounged up an "A" lighter somewhere and figured it would fit because the knob looked the same but I was wrong. You can screw the knob off but the element won't fit in the hole.
Old 11-10-2011, 08:00 AM
mviker's Avatar
mviker mviker is offline
I've got the type A in my 62 GP. I guess that's the Rochester. It looks fine, but doesn't work for some reason. All new wiring to boot.
Old 11-10-2011, 12:13 PM
Formulabruce's Avatar
Amazing this got sticky in the Lobby.. must be a 69 GTO is involved LOL
" Long may we DRIVE !"
Old 11-10-2011, 10:58 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
'71 and '69 LeMans, both Fremont plant, both Rochester.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 11-18-2011, 08:50 AM
Woodchuck Woodchuck is offline
Default Lighter
Hi Mike, I have a 68 bird with a rochester.
Doug
Old 11-18-2011, 06:58 PM
Just call me Sean's Avatar
Just call me Sean Just call me Sean is offline
'72 LeMans, type A.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Old 11-18-2011, 07:04 PM
lilabner's Avatar
lilabner lilabner is offline
My 61 Catalina built in California is a type A
Old 11-27-2011, 09:58 PM
irgoatmike irgoatmike is offline
67 GTO, built in Kansas City, Type A. Irgoatmike
Old 11-28-2011, 11:09 AM
gtoric's Avatar
gtoric gtoric is offline
'67 GTO, K.C., MO - Rochester
'67 GP, K.C., KS - Rochester
Old 01-22-2012, 04:38 PM
mgoblue mgoblue is offline
Found this CASCO tag this weekend while sorting thru some stuff in the basement. I wonder if they are reproduced. Be nice to attach to the lighter while at car shows.
Old 01-22-2012, 04:43 PM
the70OOJudge's Avatar
the70OOJudge the70OOJudge is offline
Send a message via MSN to the70OOJudge
Originally Posted by mrgto69 View Post
Hi everyone, I need your help. We found a bunch of new Casco lighter assemblies and we need to know what year car goes with what type of insert. Different Pontiac plants used different lighter inserts for the different models. Please take a look at the picture and then take a look at your insert in your dash. I'm not concerned as much with the knob as the filiment...the knob will unscrew.Type A is a Rochester insert and Type B is the Casco. Which one do you have Type A or Type B & what year/make/model?
Thanks... GP Mike
1970 Canadian built GTO Judge and have the Rochester one Type A
Old 01-23-2012, 12:43 AM
mrgto69's Avatar
mrgto69 mrgto69 is offline
Pypes Staff - Tech
I have a limited supply of Casco lighters and I'm planning to make some 64-5, 66, and 67-72 lighters this week.
Thanks for all your help.
GP MIKE
Old 01-23-2012, 11:50 AM
Have you tried checking to see if there is current to it.. the outer shell is negative as its ground to the dash frame, and the centre is positive.. should have power all the time. Funny the lighter nowadays is to charge up an ipod or something like that and not a smoke :>)
Old 05-02-2012, 08:17 PM
dj69gto dj69gto is offline
I have a 1969 GTO built February 69 in Fremont CA with a type B Casco lighter. The knob is smaller, though, and it has the light which clips onto the outer case. Do you sell the Casco lighter by itself with the larger knob?
Old 05-02-2012, 11:53 PM
mrgto69's Avatar
Pypes Staff - Tech
Thank you for responding to my post. I have decided to make 3 different Casco lighter packages...
PYI72LCK - http://www.pysales.com/images/pyi72lck.jpg for $40,
PYI73LCK - http://www.pysales.com/images/pyi73lck.jpg for $40,
PYI74LCK - http://www.pysales.com/images/pyi74lck.jpg for $40.
There is a limited supply instock, so for anyone who needs them, please give us a call for order online.
Thanks... GP Mike
Old 05-03-2012, 01:48 AM
FrankieT/A's Avatar
I've never seen a casco style in an F body. Although I changed mine over to casco. I put the original knob from my Rochester onto the casco element with casco socket. Pretty much looks original but I don't have to worry about a melt down anymore.
  #38
Old 05-12-2012, 09:10 PM
Default casco lighters
What is the difference between the PY172 and the PY174? Thanks -
  #39
Old 05-14-2012, 12:38 PM
michaelroy's Avatar
michaelroy michaelroy is offline
Default lighter
My 65 Lemans has a type B but the knob does not match the other knobs which all look like the Type A.
I recently purchased a new type A to match the knobs but its too large to fit in the socket????????
The type B lighter I have works great but looks like crap sinse it dosent match the knob of typr A.--------Hope I didn't confuse you.
  #40
Old 07-02-2012, 01:57 AM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Type A 69 FB
