#201
Old 02-01-2012, 07:53 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by shaker455 View Post
Any more info like carb used, jetting, timming & curve?
40 Degrees timing
Prosystems 1050 Jets 93 HS 35
  #202
Old 02-01-2012, 08:24 PM
very nice numbers for a turbo motor NA
  #203
Old 02-01-2012, 09:20 PM
Silver Judge's Avatar
Thumbs up
Latest Pics from BES.
So, even though you can't judge a book by its cover, that is one fine looking engine.
Love the look of those RAV heads, the intake with the big runners, those injectors and those honking headers, just waiting for the big ass turbos
501 HP, 554 ft lbs TQ
  #204
Old 02-01-2012, 09:50 PM
Travis Q Travis Q is offline
Hey Lynn, what's the combustion chamber look like in those heads? Pretty open? 40 degrees suprised me a little bit. If the chamber is open, though, it will really widen the tuning window a lot.
Curt - I wish we had GT55s on ours. Controlling power with boost is probably a bunch easier than how I have to do it. I can only get away with it because of the clutch. If it was an auto, it would be game over. CID doesn't mean as much with a clutch in terms of getting the turbos spun up, but it's everything with a converter. Stroke is king with a converter, so long as the tire can tolerate it!
  #205
Old 02-01-2012, 10:07 PM
RAIV-Z's Avatar
Here is a picture of the chamber, it's ~81cc.
  #206
Old 02-01-2012, 10:27 PM
"She's So Pretty!"
Very nice numbers for the rpm pulled.
Tom Vaught
  #207
Old 02-01-2012, 10:33 PM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
Default RAV Street Engine Dyno Normally Aspirated
9.15 to one
mildly ported CNC heads
2 inch street headers
no evac system(yet)
252@050
1.65 Rocker Ratio
pulled with 1050 dominator carb.(prob a few more ponies with 2000cfm EFI)
Tony thinks this engine did very well.
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
www.ChemicalManagementIndiana.com
317-260-3486
  #208
Old 02-01-2012, 11:21 PM
lemans411's Avatar
lemans411 lemans411 is offline
Originally Posted by NHRASuperStock455SD View Post
I believe that the biggest issue with your engine is probably heat. I am hoping with our improved water jackets and no siameze water jacket it helps with the sealing. All I know is his traction control better be hooked up.
my engine does run hot and im sure that doesnt help much
-Rob
67 LE MANS in pieces...
68 gto
84 grand prix twin turbo 496 pontiac 25.3 cage
  #209
Old 02-01-2012, 11:23 PM
lemans411's Avatar
my 535 made around 620 tq n/a. fyi . with a lot less flow i bet lol
-Rob
68 gto
  #210
Old 02-01-2012, 11:54 PM
Default pictures
Name:	dyno picture.jpg
ID:	273053   Click image for larger version
ID:	273055   Click image for larger version
ID:	273056   Click image for larger version
ID:	273057   Click image for larger version
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #211
Old 02-02-2012, 12:01 AM
lemans411's Avatar
do want!!!!!!!!!!!!!! drooollll!!!!!!!!!!!!!!!!!!!!.
i'm going to go buy a lottery ticket right now
-Rob
68 gto
  #212
Old 02-02-2012, 12:34 AM
ID:	273059   Click image for larger version
ID:	273060   Click image for larger version
ID:	273061   Click image for larger version
Lynn McCarty
dba/McCarty Racing
www.RamAirV.com
[email protected]
317-260-3486
  #213
Old 02-02-2012, 03:27 PM
cgeise's Avatar
cgeise cgeise is offline
Those new -- expensive -- shocks seem to be helping that tire issue - at least so far --The gt55 turbine wheel really helped the backpressure issue and reduced ex temps a lot -- Now if I gould just get a waist gate that will NOT stick ------------
  #214
Old 02-02-2012, 11:08 PM
jdw_poncho's Avatar
jdw_poncho jdw_poncho is offline
Looks good Ed, cant wait to see a video with the turbo's attached to it.
  #215
Old 02-18-2012, 08:28 PM
RAIV-Z's Avatar
More cutting on the chassis today.
  #216
Old 02-20-2012, 08:40 PM
67'7F6'Bird's Avatar
Do you have any pictures with the lights on? And I don't mean the headlights.
  #217
Old 02-20-2012, 09:00 PM
455firebird1969's Avatar
The flashlight's on...
  #218
Old 02-25-2012, 08:00 PM
RAIV-Z's Avatar
Just about finished with all the cutting.
ID:	276353   Click image for larger version
  #219
Old 02-28-2012, 06:51 PM
cgeise's Avatar
be carefull it doesnt sagg or flex with out any support
  #220
Old 02-28-2012, 07:58 PM
RAIV-Z's Avatar
We were very careful with it. The car was a little tweaked to start with, we're going to put it on a jig and straighten it out before we start constructing the cage.
