Old 04-13-2012, 08:57 AM
67'7F6'Bird's Avatar
Thank ponjohn, Answers below.
Originally Posted by ponjohn View Post
This thread is FANTASTIC!!
I have a few questions.
As you remove and reinstall panels to test fit how do you know it's going back in the same exact spot? We used small self tapping screws in multiple locations.
How did you determine where and how many plug weld holes to use? Depending on the size of the plug weld needed we spaced them accordingly, about 1 to 2.5 inches.
Does the rain gutter stay on the car even when the roof and quarter is removed? Yes, The gutters remained attached on this build.
Keep us updated.
John
Old 05-13-2012, 09:27 AM
A few updates...
We installed the Transmission Cooler with Fan, the Electric Fan for the Radiator, Fan Shroud and the Derale Fan Controller. The real tail-Pipe Hangers we welded on too.
Steve
ID:	284325   Click image for larger version
ID:	284326   Click image for larger version
ID:	284327   Click image for larger version
ID:	284328   Click image for larger version
Old 05-13-2012, 07:22 PM
frankyboy455 frankyboy455 is offline
Originally Posted by 67'7F6'Bird View Post
A few updates...
Steve
didn't you want to bolt them on like the factory did ?
Old 05-13-2012, 07:43 PM
I needed the welding practice in tight spots.
It looks cleaner this way.
Originality can be Improved.
Those little factory bolts wouldn't hold up this 3" tailpipe. HAHAHA
Old 07-14-2012, 11:56 PM
We put the "Super 400 Hood" on the car. The fit is OK, it does need some time for overall clean-up from the mold process. the middle sides of the hood which run along the fender seem about a 1/4" high. I may need Dzus fasteners to run along side the hood for proper fitment to pull it down. Pictures to follow.
Old 08-12-2012, 09:10 AM
I received the "Universal Spinners" 2" Drop Base and Flat Lid with middle recess for the Air Cleaner Bolt. This stuff is Very Nice and I recommend them to anyone who need more hood clearance.
http://www.racingjunk.com/Drag-Racin...-drop-16-.html
Once installed with my Super 400 Hood and 3.5" K&N Air Cleaner the hood still doesn't close all the way and it needs about 1/2" More clearance minimum. Instead of cutting the Victor Intake down I am going to order the Northwind Intake which is 1.25" shorter than the Victor with comparable flow.
http://www.krepower.com/Pontiac%20Intakes.htm
Steve
Old 08-24-2012, 10:45 AM
4500 Northwind RAIV Ports Intake being Delivered today.
