#61
Old 03-24-2012, 10:42 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Originally Posted by hgerhardt View Post
As for tire sidewall height (diameter), I agree 26-27" dia is ideal. A 255/45R17 is 26.1" dia and is easy to come by and will fit even an early A-body, as I have on my '66 GTO as below. Here are Firestone Wide Ovals in that size: http://www.tirerack.com/tires/tires....omCompare1=yes Click on Specs to see the sizes.
These wheels are ROH ZR6's, which were the prototypes for the Impala SS. I used '69 Bonneville hubcap centers which fit perfectly in the ROH centercaps. Brakes are 13" Corvette C5 front and 4th gen F-body rear (same calipers as the C5 except they are a bolt-on to our rear axles). Wheels are 17x8.5 reverse-mount, which is what the YO Rally II's are, and caliper clearance is very tight.
Love that car dude! I remember it from the Hot Rod article. I still have the magazine around here someplace.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #62
Old 03-25-2012, 12:09 AM
Those wheels look perfect. They look like they fit tight against the body and dont stick out. Very nice.
  #63
Old 03-27-2012, 03:36 PM
ClassicDriverMan's Avatar
ClassicDriverMan ClassicDriverMan is offline
Default Mario65 - The stance and look you want
Hey Mario65,
In post #45 you said,
"FirebirdMI thanks for your work and time on this. I know we all are going to get alot of it. I really hope it works for you. I have been rediculously patient. I am getting the bug again. I dont want to spend 4k on wheels and tires if I think I can get a Rally II look to work.
Heres my current stance and look:
http://transams.net/MariosCollection...rd_400.html#16
Heres the stance I and look I want. I would much rather have a Rally II wheel do it than aftermarket wheels.
http://i168.photobucket.com/albums/u...p/DSC_0125.jpg
Do you happen to know what those wheels/tire size are? I too like that look very much. Any ideas.
Just wondering.
  #64
Old 04-13-2012, 12:06 AM
mario65's Avatar
mario65 mario65 is offline
Originally Posted by ClassicDriverMan View Post
Hey Mario65,
Just wondering.
Sorry I didn't get back,
Just saw the post.
"17x8 4-7/8 backspace on front and 17x11 5-1/2 backspace on rear. 245/45/17 and 315/35/17 bfg KDs . DSE mini tubbed
All DSE front end, coil over relocation, koni's, DSE UCA/LCA etc. Back is DSE 3" drop leaf w/offset shackle, so basically its lowered 3". No problem with front rubbing, I could pick it up another 1/2 inch but I like the stance."
TransAM Depot The Judge GTO Coupe prototype, DUCATI ST4s DP, Buick Turbo T WE4 not stock.
  #65
Old 04-14-2012, 01:29 AM
Nicks67GTO Nicks67GTO is offline
Has anyone seen these with some 50 or 55 series tires on an A body yet?
  #66
Old 04-18-2012, 08:12 PM
john31s john31s is offline
I plan on running 50 series tires.
Also can I get away with running 255's up front and 275's out back. The suspension is pretty much stock, but I plan on changing that after I get an idea of what I can do and still fit the tires.
1970 Lemans 350/ TH350 ProTouring Madness
  #67
Old 04-27-2012, 07:42 AM
mario65's Avatar
I called them yesterday and still no news on the 8"
  #68
Old 04-27-2012, 07:48 AM
mario65's Avatar
I think I am just gonna bite the bullet.
275/40/17 Drag radials on the back
245/40/17 on the front
Worst case they'll stick out a little
  #69
Old 04-27-2012, 01:46 PM
Did they give you any time frame for the 8"?
  #70
Old 04-27-2012, 10:24 PM
mario65's Avatar
nope they don't have a clue
  #71
Old 04-28-2012, 10:08 AM
DevoBuzz's Avatar
DevoBuzz DevoBuzz is offline
If you want the approx same size on the front and back, it would be 245/45/17 front.
  #72
Old 05-02-2012, 04:40 PM
to anyone who is running these now, I got mine and it looks like I need longer studs. I'm afraid the lug nuts don't have enough thread to bite on.
  #73
Old 05-02-2012, 04:48 PM
mario65's Avatar
how many turns are you getting I think you need 5 or more
  #74
Old 05-02-2012, 04:53 PM
mario65's Avatar
if you still feel like that's not going to work you can get ET style loves that will help. I have used them with half inch spacers
  #75
Old 05-03-2012, 05:48 PM
DevoBuzz's Avatar
Yes I had the same concern. I went with it but would like more thread engagement.
Would these work?
http://www.summitracing.com/parts/BSP-999970/?rtype=10
  #76
Old 05-03-2012, 10:09 PM
I'm going to see if the ET lugs will work. Other wise I'll just put new studs in.
  #77
Old 05-05-2012, 04:59 PM
silvergoat silvergoat is offline
Default 69 gto rubbing with the new year ones
I just got my new year one rally 2s
I used the same bfgoodwrench kdw nt 275/40/17 tires. The rears are fine , but the fronts rub on the front and back of the fender . Any suggestions would be awesome.
  #78
Old 05-06-2012, 01:26 PM
I just put mine on the car. I have Nitto 555's with 255/45-17 on the front and 285/40-17 on the back. That gives me a 25.94 inch tall tire both front and back. The lug nuts do not inhale the studs anywhere near enough. I going to switch the studs for longer ones because I don't think a set of ET lug nuts would fit. I'll post a picture of them on the car later.
  #79
Old 05-11-2012, 12:01 AM
Default have to drop the front now
just put mine on , had to go with 245/40/17 front, 275/40/17 rear
i dont think anything else would fit upfront
ID:	284159   Click image for larger version
  #80
Old 05-11-2012, 12:19 AM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
Those look pretty awesome!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
