Old 04-27-2012, 12:36 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Now that I've got the body bolted back to the frame, it's time to put the roll bar in. I put pilot holes in the floor and trunk before I rolled the shell rightside up. So I wouldn't cut any more than I had to. I put the main hoop in and welded it to the frame. I used re-bar to make the shape for the two bars that go into the trunk. Dropped them off at a local metal shop to have them bent correctly.
Name:	roll cage in the aerocoupe 007.jpg
ID:	282880   Click image for larger version
Name:	roll cage in the aerocoupe 008.jpg
ID:	282881   Click image for larger version
Name:	roll cage in the aerocoupe 009.jpg
ID:	282883   Click image for larger version
Name:	roll cage in the aerocoupe 011.jpg
Old 04-29-2012, 08:05 AM
This is the only way I'll be able to weld the roll bars in the trunk area. Also the fuel cell is not going in through the aero coupe trunk opening. You've only got 10 1/2 inches of trunk opening and have part of the trunk latch in the way!
ID:	283080   Click image for larger version
Name:	stacy's aerocoupe 004.jpg
Old 04-29-2012, 08:54 AM
oldtinsmith oldtinsmith is offline
I'm lov'n this build! What type of paint did you use on the frame (and was the frame sand blasted?).
Doug
Doug
Old 04-29-2012, 03:28 PM
Doug
Doug, glad your liking the thread. I'm enjoying this build, having to be a little more creative than just restoring. As for the frame I did sand blast it. But prior to that I scraped the old "Rusty Jones" tar treatment off it. I used an etching primer then urethane primer prior to painting. I couldn't see using a high dollar rust preventative[$$$] paint since I had already invested my time and effort to make this frame rust free. I used Rustoleom oil based black and cut it about 10% with mineral spirits. I let it sit for awhile knowing that the curing process would be slow. I don't think I'll be disappointed with it. The frame shouldn't fade to much since it wiil be hidden from the sun. The rest of the car is being painted with automotive grade paint.
Old 04-30-2012, 03:15 PM
Just ordered the manual brakes master cylinder part #10-1905 "Cordone" from Advance Auto. $33.99 will be in tomorrow morning. Then I called Master Power and ordered the firewall plate adapter needed to complete the conversion. Part # AD2732K . I first checked on the =ir online catalog and that adapter plate wasn't listed for the 78-87 g-body. Talked to one of their tech guys. He said he was pretty sure that it worked but would physically get one out and call me back so we could compare measurements. He called me back and the part did check out for the good. So I ordered it. Needless to say I was happy with their tech service. All the info that I have for this conversion has come from the PY forums, again showing how valuable this forum can be for us Pontiac people.
Old 05-01-2012, 12:53 AM
SmallHurst SmallHurst is offline
Very cool that this car is getting the love they all deserve.
I am sure that with this powertrain, you are looking at different rims and tires. For those who are looking at restoring one and want the original look, Kelsey has just reintroduced the Eagle GT in 215/65/15 and 255/60/15. Here is a pic to remind you of what was the coolest tire at the time.
http://www.kelseytire.com/pages/larg...p215-65-R.html
If you have any questions about these tires, I am happy to help!!!!
Russell Small
1969 Hurst/Olds
13.26 @103.1
"Pure Stock is the way to Rock"
Old 05-01-2012, 11:33 AM
I do plan on using Pontiac rally II's. 15X8 for the back. Hadn't given much thought to the tire. This is good to know, thanks.
