1) iron head is stiffer and would bridge across the head bolts better. 2) the head runs hotter than the block. Iron has a lower coefficient of thermal expansion. So....that mix would tend to equalize the thermal expansion of the two and minimize the movement along the deck surface. But if someone has actually tried it and it didn't work well, that would override theroy. FWIW, Eric |
"One test is worth a thousand expert opinions"
author unknown but that's been a favorite of mine for years. Eric |
Even then..........
Has the cometic been surviving with this mod? Seems like the raised sealing embossment in that area flattens out with the heat then you just end up with 3 flat layers in that area. Good idea, hope it works out. MK
505 CID, 3560 lbs,Tiger heads, NA. [email protected] mph, 1.29 60', stock suspension |
Calvin Hill Hill Performance 708-250-7420 |
