Old 05-07-2012, 09:30 PM
ho421's Avatar
ho421 ho421 is offline
Originally Posted by mikes2nd View Post
This is why I like silver bullet better... much better. I only use POR15 on stuff I can reshoot.
I silver bulleted the whole car, then sprayed undercoat paint on the bottom(not the thick heavy rubber crap). Never put rubberized undercoating on your car.
http://www.rustbullet.com/Products/A...Automotive.asp
Can you expand upon non-rubberized "undercoat paint"? I too have used rust bullet with success but as the others have said above, it either sticks or comes off in sheets and IMO the same would apply to POR15 and Chassis Saver. The key is prep. I intend to use the metal impregnated (silver) rust bullet on the underside but intend to take a few extra precautions. I'm going to remove all flash rust and scale with a cup brush on an angle grinder, followed by a cleanup using a prep solvent (GON) and finish by etching the underside with POR15's Prep-n-Ready. After I coat with Rust Bullet, I want to cover that nasty silver stuff with "something" black. So, I'd be interested in knowing what would be a good undercoat paint to topcoat the Rust Bullet.
Old 05-08-2012, 12:16 AM
mikes2nd mikes2nd is offline
i used eastwoods rust encapsulator over the silver bullet.
I wonder about lizard skin though...
