#81
Old 05-11-2012, 06:45 AM
mario65's Avatar
mario65 mario65 is offline
Originally Posted by 428GTO70 View Post
Those look pretty awesome!
Looks great. Can you send us some cloeups of the fronts. curious as to how that size tire fits the wheel. Thanks
TransAM Depot The Judge GTO Coupe prototype, DUCATI ST4s DP, Buick Turbo T WE4 not stock.
  #82
Old 05-11-2012, 11:18 AM
john31s john31s is offline
Here is my car with the YearOne Rally II's. I'm running 255/45-17 on the front and 285/40-17 on the back and their is no rub even at full lock. I just need to lower the car now to finish off the look. Just as a heads up to anyone looking at buying them, you need longer wheels studs because the wheels are so much thicker that the stock stamped steel ones.
ID:	284188   Click image for larger version
1970 Lemans 350/ TH350 ProTouring Madness
  #83
Old 05-14-2012, 08:43 AM
73GPSteve 73GPSteve is offline
John31s did you end up using the Et's or did you put on longer studs?
  #84
Old 05-14-2012, 08:50 AM
mario65's Avatar
I wonder if the mount takes a tapered or flat lug.
Maybe you need to use the YO lugs?
I looked at a pic of the YO 69 bird and it seems that they used the flat style lugs they sell with the rims like the snowflakes.
I ordered YO 17x9 cast snowflakes for my 78 Bandit. I havent got them just yet. They take the same lugs as on the original snowflakes which clearly arent the tapered steel rally wheel lugs.
  #85
Old 05-14-2012, 09:00 AM
I already have mine, they come with a tapered lug. I also didn't like the amount of thread so I got longer studs, got the front done but I can't find a long stud for the rear with the right knurl, ordered .480 and they were too big. So thinking might just run with the ETs if they work. Car is a 1973 Grand Prix, I'll post pics as soon as I get them on.
  #86
Old 05-14-2012, 09:51 AM
I put new studs in. Thiers no room for the ET style lug nuts or that's hat what I thought.
As far as lug nuts from YearOne goes, they sell them with the same nuts thr PY sells. Thier chrome with either black or red inserts, not some specially lug nut.
  #87
Old 05-14-2012, 10:01 AM
John What studs did you get for the rear? Like I said I'm having trouble finding ones that will fit. .480 is too big
  #88
Old 05-14-2012, 11:16 AM
I used .480 out back and .570 up front. If .480 is to big just measure the inside diameter of the hole with a feeler gauge and just order a size or two big. I used jegs part number 555-65101 and 555-65100 which both give a range of hole sizes they will fit.
  #89
Old 05-14-2012, 05:56 PM
mario65's Avatar
You guys should really consider these before studs. I ran them with a 1/4 spacer on Buick Regal -T and they were great. IF you find you still don't have enough thread then get studs.
http://www.jegs.com/i/Billet-Special...oductId=757188
  #90
Old 05-14-2012, 05:58 PM
mario65's Avatar
Besides if you do studs aren't you hosed if you go back stock since the factory lugs are closed end?
  #91
Old 05-14-2012, 06:03 PM
mario65's Avatar
It seems strange YO didn't use the lugs they push with the rims.
http://dl.dropbox.com/u/1714619/69birdYORallyII.jpg
  #92
Old 05-14-2012, 08:23 PM
Yea. When I bought the extended lug nuts I needed to cut them down to fit them under the closed end nuts with the red ends. Well when I had them on the lathe I set what I thought was the right length, and my friend said they were too long, and I ignored him and they are. They are a 1/16 of an inch too long so they punch through and ruined all the red centers just knocking them out. this pissed me off because I loved those red centers. I might paint the end of the studs red for looks.
And I won't have to worry about going back to the original wheels because I'm butting big brakes on which won't fit under any wheels smaller than 17 inch.
  #93
Old 05-15-2012, 08:34 PM
mario65's Avatar
I threw some 17x9 YO snowflakes on the 67 bird to get some measurements.
http://forums.maxperformanceinc.com/...88#post4632888
  #94
Old 05-16-2012, 05:07 PM
DevoBuzz's Avatar
DevoBuzz DevoBuzz is offline
I emailed Year One:
"I have recently purchased the Pontiac Rallye 2 17x9 aluminum wheels and I am concerned about the thread engagement of the lug nuts. It seems the wheel is thicker than a standard steel wheel and the thread engagement is much less. Do you know what the corrective action for this is? Do I need to purchase longer wheel studs or extended tip (ET) lug nuts? I was wondering if this issue was encountereed during product development and how it was addressed."
and this is what they said:
"The thread engagement depends on the length of the existing lug studs. When people find less than minimum thread engagement we recommend extended shank lug nuts as this is easier than locating and installing longer stock type studs. We do not usually recommend racing type long studs as they are too long to use with capped lug nuts and require open ended nuts."
So I ordered a set of ET lugs from Summit. I'll let you know if they fit or not.
  #95
Old 05-19-2012, 09:49 AM
DevoBuzz's Avatar
I put the Billet Specialties ET lugs on and they work fine. Just be aware - they come in 10 packs not 20. So now I have order another.
1972 LeMans
461 stroker 10.3:1
Edelbrock D ports Scorpion 1.5 rockers
Comp Cams "Stump Puller" roller
Holley Ultra Street Avenger 770
Ram Air III exhaust manifolds
2.5" pipes Dynomax VT w/crossover
Edelbrock Performer RPM
TH350 2.78:1 10 bolt
  #96
Old 06-13-2012, 02:37 AM
RAFO9A's Avatar
RAFO9A RAFO9A is offline
Exclamation 17x8 now available
Checked Year One's website tonight and found out the 17x8 version is now available with 4.5" backspacing:
https://yearone.com/Product/DisplayProduct/509466
Raffi R.
1968 Firebird: 350 .040 over, #11 Heads w/2.05/1.66 valves, Tomahawk TC-03 cam (214/221 flat tappet cam, 112 LSA, .0450/.0465 lift w/ 1.5 rockers), 200-4R w/3.55 gears, Street Demon 625 w/ Edelbrock Performer, H-Pipe dual exhaust w/Delta Flow 50's.
  #97
Old 08-13-2012, 12:38 AM
ClassicDriverMan's Avatar
ClassicDriverMan ClassicDriverMan is offline
I have 1/2 inch diameter studs... Would this be a problem? Just checking.
I will contact YO.... but maybe those with the wheels might have a more objective opinion.
Tribal Tube Header Rip Off Victim. Ordered March 27, 2012. Told 3-4 weeks. Still waiting
  #98
Old 08-19-2012, 12:08 PM
JC455 JC455 is offline
Any update on the 1/2" stud question?
John
IG: @crawdaddycustoms
  #99
Old 08-19-2012, 12:35 PM
I haven't checked with YO since I am a few months away from getting wheels. I checked some shop rollers and they seem to work. But you never know. I would think it should not be a problem. Would like to hear from those who actually have these wheels.
Anyone?
  #100
Old 08-23-2012, 10:17 AM
Nicks67GTO Nicks67GTO is offline
Has anyone seen these on a 67 A-body yet? Preferably with some 50 series tires??
