Or down below the molding?
From what he said, past the molding towards the center of the car. Below the molding.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
That's what I figured.
I believe my 70 Formula also was 'black' below the molding, basically on the flat part underneath where it isn't seen? I repainted it about 30 years ago, so may be foggy on that.
I have an original 70 formula that has black on the flat part 'below' or 'down past' the molding. I just figured it was the underside black (CA built car) that didn't get any paint on it. It doesn't look like it was purposely black in that area. One side of the car has more black than the other.
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
Next time I'm in the building where it's stored I'll try to get some pics.
My original paint 70 formula had the blacked out area on the front valance (also pictures in an earlier post). Now that I think about it, it makes good sense that all valences would have had the black treatment. The plants could not have been bothered to skip the black-out on the 6% of Firebirds that were built into Trans Ams. Crap! Now I have to add black to MY valance! |
http://www.forums.maxperformanceinc....d.php?t=493870
giles, this one? |
As far as the "black out" treatment...Look at all the original pictures, you can clearly see white overspray. Telling us that the black was there first. Hard to get overspray if the black was put on 2nd?? |
Ric.... you know..my only answer is you are wrong. You stated that the silver ones were most likely repo's, I showed a old style boxed one,with the complete assembly that was silver..sort of proves they were not repos.. Same with the yellow one. I am never always right as none of us are..I accepted this a long time back... SO in this instance, respectfully I say you are incorrect..You know..1968(or one of these years +/-1 yr) RA pulloffs were recalled for leakage and the factory replaced all with a black one and put a yellow paint dab to mark that it had been replaced.. I am sure many owners of these cars believe theirs is original as well. Correctly replaced, but not original.. Ric, unless you bought the car brand new from the dealer...I just don't believe it.. 1970 Non RamAir cars had the metal canister with double vacuum ports and RA cars have the 1970 only yellow cannister. I have seen pictures of more than one like this, but only touched the one on the 18K mile RAIV in ALberta Canada that I flew up to photograph.. As I said,, you guys will believe what you want to..that is fine..I am just trying to give some insight to what I have discovered.. Take it or leave it..Helll, put a pink pull off on you car and call it correct for all I care..
