Old 05-14-2012, 04:13 PM
Glenn Sedig Glenn Sedig is offline
Default Tiger Inserts
New inserts where tried at Cordova on Fri and Sat for the West Q-8 bracket race. Stars where aligned correctly and won the race. Have to believe the inserts worked very well as this engine has never been this consistant except for the first several runs after changing the head gaskets.
Fri 4500 launch rpm--------60ft
1st run-8.82 @153.96-----1.302
2-------8.84 @153.30-----1.303
3-------8.83 @153.61-----1.293
Sat 5500 launch rpm
1st------8.76 @152.76-----1.241
2--------8.77 @153.44-----1.250
3--------8.76 @153.70-----1.252 elimination run
4--------8.75 @153.35-----1.253 elimination run
5--------8.75 @153.65-----1.246 elimination run
For the car to be this consistant I am quite sure there was no insert problem or head gasket leak. We are checking leak down today to see if there are any changes.
Old 05-14-2012, 07:36 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
Glen congrats on the victory, please keep us informed on the leakdown. I am getting tired of buying headgaskets and shaving the heads. thanks MK
505 CID, 3560 lbs,Tiger heads, NA.
[email protected] mph, 1.29 60', stock suspension
Old 05-14-2012, 07:41 PM
Thumbs up
[QUOTE=Glenn Sedig;4631844]New inserts where tried at Cordova on Fri and Sat for the West Q-8 bracket race. Stars where aligned correctly and won the race....this engine has never been this consistant except for the first several runs after changing the head gaskets.
Sat 5500 launch rpm
For the car to be this consistant I am quite sure there was no insert problem or head gasket leak. We are checking leak down today.../QUOTE]
Stellar results. LETS begin to ponder the berylium bridge connection to consistency. Cool running allow 4 CYLS to fire better (at proper advance)?
Old 05-14-2012, 08:49 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Extremely consistent, looks like you found some HP with the increase in MPH too.
Calvin Hill
Hill Performance
708-250-742-
Old 05-15-2012, 08:11 AM
Hey, interesting. I'd like to hear what the PROs are thinking about now.
Old 05-15-2012, 09:47 AM
GTOGEORGE's Avatar
So................Glenn, how much were you squirting it? Glad to hear everything seems to be A-OK.
I'm using a double o-ring set up in my engine and after 50 or so runs (only at 9-11 lbs. of boost) everything was OK. When I took a leak down test.
GTO George
Old 05-15-2012, 10:31 AM
GTO George
Glad ur having success with ur set up George! I think u might find if u turn the wick up in the mid to high 20lbs, u might find there is a bit more maintenance and issues... you are running at relatively low boost. Don't know if u ever plan to turn it up that high? If you do you will certainly fly but it comes at a cost with issues like this...
Old 05-15-2012, 12:11 PM
GTOGEORGE's Avatar
Scott I understand that I am not running at high boost levels right now, just was wondering what Glenn's set up is on his 7 passes.
George
Old 05-15-2012, 01:53 AM
john marcella john marcella is offline
Sat 5500 launch rpm
Good deal Glenn. Congrats on the win as well
I was sceptical at first but it is looking like my initial thoughts were wrong. Ya learn something every day
Old 05-15-2012, 07:13 AM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
congratso on the win. how much were you weighing ?
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 05-15-2012, 01:27 PM
You probably wouldn't believe 3195 lbs. So I won't lie. 2950 lbs
Old 05-15-2012, 01:44 PM
dont lie to me!! LOL.. i think it was 3195!!
good job
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 05-15-2012, 02:03 PM
Leak down before the inserts were installed, and with 15 runs on the old gaskets, on cyl 3 & 5 was 15%. On cyl 4 & 6 was 8%. The heads were installed with new gaskets. The cylinders heads were flat with no bad areas except between the center cylinders. I got more than 15 runs (more like 30 runs) when the heads were new and no deformation had occurred in the center area.
The inserts where installed to sit .001 above the head surface. The heads have not been surfaced since new. The leak down after the 8 runs - 3 & 5 is 2% 4 & 6 is 3%
Engine is 473 Cu in, 14.5:1 comp. N/A
I need to clarify the engine consitency. Along with the inserts and new head gaskets, I changed my valve lash from .026 cold to .010 cold. Hoped to achieve .018 when hot. I believe the lash change and the fact that the track was prepped before each Q - 8 session also helped with the consitency.
Old 05-15-2012, 04:12 PM
60man's Avatar
60man 60man is offline
Thanks for the info Glen..I don't have a leak down handy ( misplaced it?) so I'm going to check compression with standard gauge...to get an idea of any present issues..??
I ran a comp. check prior to past week ends passes..
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
Old 05-15-2012, 06:31 PM
It would be good if you can find your leak down tester. The compression happens so fast when you crank your engine over that it is hard to tell if the gasket is starting to leak. If the gasket is bad and you put the cyl at TDC and add air pressure, you will hear the air leak into the neighboring cyl. Of course you will also hear if your valves and rings are leaking.
Old 05-15-2012, 08:46 PM
Those leak down numbers are really good, do you normally re-torque the head once it's been on a running engine for a number of heat cycles?
I really believe, due to the nature of this insert material, this will solve many of the head gaskets woes our tied together, Pontiac siamese exhaust engines can have. Once the exhaust temps get so hot, the small amount of mating surface will not cool properly and weakens.
In today's bigger bore engines, our larger bore spaced cousins (BBC) have other issues when the chambers begin to collapse due to the lack of surface real estate.
Increased power will always come with a cost.
Calvin Hill
Hill Performance
708-250-7420
Old 05-16-2012, 07:23 PM
Calvin Hill
Hill Performance
708-250-7420
No I do not. I know I should but there is never enough time.
