Old 06-03-2012, 07:37 PM
78T/a's Avatar
78T/a 78T/a is offline
Default Cal-Tracs vs. Slide-A-Links
Hey everyone
Im done with the slapper bars on my Street/Strip 78 T/a, and thinking I want to try either the Caltarcs or the slide-a-links. I was wondering if anyone has had any experience running either of these on a street car, keeping ride quality in mind
Mike
1978 Trans Am/ Pontiac 400/ #62 heads/ Eddie performer/ Holley Street Avenger 670/ Headers/ Pypes X into flowmaster 44's/ 3.42 gears/ Nitto DR's/ Best E.T. 13.25@ 102.02....
Old 06-03-2012, 07:40 PM
Money Pit's Avatar
Money Pit Money Pit is offline
Brian Baker's Avatar
I ran Cal-Tracs, and for a factory suspension, I wouldn't run anything else.
Old 06-03-2012, 07:44 PM
78T/a's Avatar
Im running Hotckis springs, with KYB Gas adjust shocks(willing to change shocks)
Old 06-03-2012, 07:55 PM
BDHABT's Avatar
BDHABT BDHABT is offline
Thumbs up
Ran the Cal-tracs for years on the street;no issues.
Check out the Assassin bars from Smithracecraft;they`re similar to Cal-Tracs,but with more adjustment.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 06-03-2012, 08:02 PM
When I say "factory suspension" I mean the original leaf sprung set-up the factory installed, not neccessarily factory spec springs and shocks. I ran Landrum springs with QA1 Stocker Stars (adjustable) in my 79 T/A.
Old 06-03-2012, 08:11 PM
Flyin TA Flyin TA is offline
I just did Caltracs with mono leaf and full set of their drag shocks. Much better lauch and felt solid during the shifts
Old 06-03-2012, 08:15 PM
JUDGE3 JUDGE3 is offline
cal-tracs, ran em on a 67 Firebird. cal tracs replace the front bushing with a solid aluminum one as you likely are aware. i used em on mine, but u can leave your original rubber fronts in for more cushion if your mostly street drivin and only occasional race.
Old 06-03-2012, 08:22 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
X2.. i just went 2 1.21 sixty foots with cal tracs and mono leafs in my 68 bird!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 06-03-2012, 09:16 PM
ponjohn's Avatar
ponjohn ponjohn is offline
Caltrac mono or landrum?
Old 06-03-2012, 09:17 PM
73 bird 73 bird is offline
I have the slide-a-links. Work good for me at the track, do nothing for me on the street. What are the differences between the two?
73 firebird 455 6x-4 heads 350 turbo 3.73 gears
1/8 7.65 @ 90.95
1/4 11.96 @ 112.60
new best in 1/8th 7.57@91 mph(4-13-12)
Old 06-03-2012, 09:40 PM
caltrac mono
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 06-04-2012, 07:41 AM
BDHABT's Avatar
Jeff,are you running sliders?
Thanks.
CCE Ported Gustram
963 HP
Old 06-04-2012, 08:16 AM
Thanks.
no...
1.079 4.52 155.15
3000 lbs
Special Thanks to:
Butler Peformance
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 06-04-2012, 06:01 PM
Vengeance Race Engines's Avatar
Vengeance Race Engines Vengeance Race Engines is offline
Cal Tracs will work fine for most guys. I personally favor the Assassin bars due the many adjustments you have to fine tune it, and the fact that I don't have to make plates with more adjustment holes for the bars that don't have them . Just depends on what your goals are with the car. Keep in mind they are not bolt on horsepower...still need a good setup in the back to get the best results, and fine tune from there..Oh, and as in Jeff's case a lot of HP helps to
Old 06-04-2012, 08:35 PM
ponjohn's Avatar
Any concern about how low they are?
Old 06-04-2012, 11:16 PM
No.
Old 06-05-2012, 09:37 AM
bankbook's Avatar
bankbook bankbook is offline
It's a matter of choice.
One of my upgrades this off season was to go complete Cal Trac combination. They have been proven time & time again.
I ran south side machines before that.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 06-06-2012, 10:27 PM
triathlonx13's Avatar
Slide A Links are made for manual transmission tranny's for Strip cars or street cars. If you do a lot of street driving - you will DEFINITELY get a better "ride" from Slide A Link
Cal - Tracs are more for strip only. And are more adjustable. Great for Automatic strip cars.
Both work fine in their intended use.
If you have a 2nd gen F-Body.... you don't need much of anything unless you are faster then 10's
Old 06-06-2012, 11:52 PM
78T/a's Avatar
Hey everyone
I took a look at the assassin bars and they are definitely some nice looking pieces. Im just not sure that i will need that much adjustability, Like I said my car is street/strip with a little more of the set-up leaning towards the street-able side, but im still having some issues with traction and some serious wheel hop, so I just want something that is going to help me put some power down with my new motor. I like the idea of keeping the rubber busing on the front with the cal tracs, but I was also reading that it is very easy to unset the pre-load on the slide-a-links so for street driving they arnt as stiff.
This is the set-up I have plan to run with which ever traction aid i choose
-Hotchkis Leafs
-Adjustable shocks(brand undecided)
-Mickey Thompson ET streets 275-60-15
-cal trac or S-A-L
Running 3.42 and planning on running a Continental Jim Hand Special Converter all being launched off foot break
Mike
