Found some more stuff I need:
1) The little bracket/tab/guide plate that holds the hood release pull bar in position. Here is the shot of what is on my Gramma's 75 Firebird: ![]() And the spot where one should be on my 72 (I removed the bracket he had installed for the inside hood release as it doesnt line up with the original location for the metal pull bar). ![]() 2) I also need a clutch fan blade for the 72 since the prior owner had installed an electric fan and a solid mounted fan blade on the engine.
And here is something for the archives: an original rear package tray. Looks like I was the first person to ever remove this thing from the car. Very interesting cutout for the single rear speaker with the center bar between the cutouts. The other funny thing is that the factory punched speaker mounting holes were all 1/2" too narrow. The factory speaker grill studs had to slot out the carboard holes 1/2" farther than the outer holes in order to line up with the factory stamped holes in the rear deck.
