Old 06-24-2012, 02:07 AM
lust4speed's Avatar
I'm wondering if there was coolant in the oil since that is about the only thing that will pit the Babbitt material that way. Do all the bearings look about the same? Were the head gaskets okay? Maybe spend a little time eyeballing the block over to see if any cylinder looks different than the others.
Mick Batson
Old 06-24-2012, 11:50 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
The guy ran straight water in the engine (and the cooling passages show it). None of the other bearings show anything similar. The head gaskets looked okay, but I don't think the guy torqued the heads down properly as it was easy to remove 1/2 the bolts and I practically had to stand on a 5' cheater pipe to get the rest off (impact gun didn't even make a dent at 90psi).
