Old 06-25-2012, 10:44 PM
Formulabruce's Avatar
Originally Posted by njsteve View Post
I forgot to post these last week when I got all the A/C hardware back in place.
I also spent some time plastic welding the ABS plastic radiator shroud. The original equipment shrouds from these cars are extremely rare to find intact. The GM replacement part has a large circular notch cut in the bottom and a bracket hole in the top for an overflow tank bracket that the 70-72 cars do not have. I have seen mint shrouds go for some big bucks recently.
Here's the shroud as is, when I bought the car. It had a 1-1/2" circular hole cut in the top and three 3/4 holes in the side and bottom, all for mounting of the aftermarket electric fan:
And here is how it looks after the welding (and inhaling of melting ABS fumes)
and the finished A/C reinstall (minus the R12).
where did you get the donor plastic? did you use one of those stitching plastic welders?
Old 06-26-2012, 07:23 AM
njsteve's Avatar
njsteve njsteve is offline
One of these units. (this is also the same unit I used to repair the polyethlyene front valances)
http://www.urethanesupply.com/Airless-Welders-1/
I used the ABS sticks and just kept applying, sanding and reapplying. I then used the SEM Landau black and misted that on to blend in the color. Completely invisible now. Did I say how much I love that SEM Landau black spray dye????
