Old 07-01-2012, 05:52 PM
165th's Avatar
165th 165th is offline
Originally Posted by Scott455HO View Post
I received mine in the mail Friday! Now all I have to do is find the thread that tells me how to get the glue off the hood from the old stripe.
Yeah! I'm glad the kits are making into folks hands. I can't wait to see some installed.
Here's a product... You really can't go wrong with a Griot's product:
http://www.griotsgarage.com/product/...sive%20remover
I wonder if Goof Off would be too strong?
Also, 3M makes an adhesive remover. Your local sign supply company would probably have that in stock:
http://3mcollision.com/products/clea...ver-08908.html
I should carry these on the website
Old 07-02-2012, 08:41 AM
FrankieT/A's Avatar
Lighter fluid for a cigarette lighters works great! But it's really just naphtha.
Old 07-03-2012, 07:49 PM
165th's Avatar
Sales of the stripe kits are still real steady. Thank you everyone who is purchasing kits, inquiring or referencing others who need them. I am very appreciative of everyone's interest.
I can't wait to start seeing installation pictures from those who have purchased kits.
Speaking of that, I am meeting a Forum member in Austin tomorrow (July 4) to install a white kit on a blue car. We'll post install pics later this week.
Old 07-03-2012, 08:08 PM
165th's Avatar
Formula400 is restoring a very original and correct white '70 RAIV TA with what may be original stripes on the car. I have previously posted comparison photos of NOS stripes with the production kits. Here are some comparison photos of an original set that has been installed on a car since new.
It's nice to see the original trunk and spoiler pin stripe and overall width actually lined up.... and it's nice to know these do too
It's also nice to see a full 1/8" thick perimeter pin stripe and equal clear reveal to the edge of the stripe.
Name:	blue stripe compare to original small.jpg
ID:	289824   Click image for larger version
Name:	spoiler stripe compare to original small.jpg
ID:	289825   Click image for larger version
Name:	blue bird compare to original small.jpg
Old 07-04-2012, 04:09 PM
165th's Avatar
Here's some pics of the kit install on the car in Austin this morning. We lost our shade mid morning and it started getting a little warm so we didn't complete the letters or nose bird.
Installation tips:
Begin with a concour correct TransAmStripes.net stripe kit.... Ha.. had to get that in
A. Install the stripes in a cool dry location. As in our case, the sun caught up to us and we couldn't finish.
B. Use RapidTac. I can't say enough good things about this product. Turns a tricky project into a smooth one.
C. Use a seamstress tape to center the stripes. Easy to use and easy on the paint.
D. Use a grease pencil to create match marks for positioning the decal on the car. Blue tape is ok to temporarily hold the stripe while your positioning but comes off with the application fluids.
E. Squeegee the fluids and air out of the stripe working from the middle to the edge methodically, covering all of the stripe, first lightly, then firmly.
F. When removing the transfer paper, do not lift up on the paper. Instead pull it back low across the surface. This will prevent the stripe from lifting from the car.
G. Overrun in the shaker opening: You can ensure proper alignment of the shaker overrun by viewing and positioning the shaker opening from the underside of the hood. After the hood stripe is installed, there should be an equal overrun of stripe around the shaker opening. Prior to completing application of the shaker opening overrun, move the car into the sunlight to warm the stripe. The heat will naturally curl the overrun down towards the shaker opening. As the stripe warms up and curls, it can be easily fitted into the shaker opening. A spritz of RapidTac or detergent/water solution will help with this fitment. The result should be a wrinkle free, clean application of the stripe overrun into the shaker opening.
H. If a bubble appears, be patient, and after completing the install, move the car into the sun and let the stripes rest. As the stripes heat up, the bubbles will shrink, and can be carefully pushed down or out with your fingers. Do no try to force the bubbles to the edge after you have a good seal on the adhesive. As a last resort, a pin prick will release any trapped air or fluids.
With all that said, here's a helpful video also:
http://www.youtube.com/watch?v=qMo2A...are_video_user
Good luck everyone with their installs!
ID:	289940   Click image for larger version
ID:	289941   Click image for larger version
ID:	289942   Click image for larger version
ID:	289943   Click image for larger version
Old 07-04-2012, 04:12 PM
165th's Avatar
a few more pics:
ID:	289948   Click image for larger version
ID:	289949   Click image for larger version
ID:	289950   Click image for larger version
