Old 07-09-2012, 12:50 AM
Bruce,
IF I can find a '59-early '60 block, we're going to have to talk about this adapter! I know you and Steve helped my a LOT when I was deciding to build a stroker for my
Cat.
Dr. Thomas Sowell
Old 07-09-2012, 02:56 AM
Steve Barcak's Avatar
Originally Posted by hurryinhoosier62 View Post
Bruce,
Cat.
They are out there. Just keep an eye open. some people throw them away as they think they are junk because they have the early bell pattern. Short sided types .
you usually can pick one up for almost nothing.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 07-09-2012, 06:43 AM
Seems there is need to standardize "critical thickness" measurements in the following block features:
Main Web width:
Lifter Bore wall:
CYL wall sonic after a 4.21 bore occurs:
Old 07-09-2012, 01:55 PM
Steve,
Believe me, I've looked. Around here, most of the late 50s vehicles went to the scrap yards years ago. I'm probably going to have to post a "wanted" ad here at PY and CP.
Dr. Thomas Sowell
Old 07-09-2012, 02:01 PM
Main Web width:
Lifter Bore wall:
Thickness/depth around mains and recesses are also significant.
69 400 cap bolt shoulder is @ 2.25" vs 59 at 2.625" ... the cap difference from the bearing surface to average outer perimeter between bolts is is over 1/4" difference.(Higher nickle content too) Main saddle area there is a depth difference thats similar. Recess differences under the dowel area even under the main bolt bosses are not just measurable but clearly visible.
When you start to study the 59 block up close in person you are left thinking... in 59 they probably knew they were going bigger in the future...and you have to consider... were they were undecided about bigger bore or bigger stroke with bigger mains?... they certainly had left enough room for 417-421 inches either way and still be bigger than Ford Chevy and Mopar at that point. (406 ford 409 chev and 413 mopar)
Old 07-09-2012, 02:31 PM
Bruce,
I really need to do a single drawing with all my notes/procedures plus better pictures. What I provided above is all I had to start with(plus a hydramatic bell and a borrowed late model std shift bell housing helped) Look for a thread on it in the future. If I thought I could sell a few I would have probably digitized it by now so it could be done on cnc.
My 1st 59 block is in Ohio somewhere last I knew... numbers matching to a 59 Catalina I sold... Block wasnt supposed to go with it...I was in Atlanta and my wife loaded it on his trailer thinking I included it... I didnt know til after I got back. That was 2006... I think we still have the guys contact info if it hasnt changed... I had the 4 bolt main caps from it and sold them about 1 yr ago... it was originally a 420A tripower package.
A few years ago someone somewhere in NY state was selling a freshly built 59... All the work had been done before he found out he'd have to add an adapter and didnt want to bother going that route... Price was very good. Check all the Pontiac sites and Ebay and Craigslist. They are out there.
Old 07-09-2012, 06:19 PM
GRX's Avatar
GRX GRX is offline
Talking
Originally Posted by BruceWilkie View Post
Depends on the year and casting.
Originally Posted by Steve Barcak View Post
From experience, I will agree with what Bruce states here.
GRX- making a statement like this- "The 400 block is stronger than the 389." is really inaccurate as there are many casting versions of each displacement. Certain 400s are indeed stronger than certain 389s but, some 389s are stronger, much stronger than any production 400 block.
You guys are absolutely right. My bad for making such an all inclusive statement.
I'll go sit in the corner with my Dunce hat on now.
I still say the way the mold was constructed, and the resulting parting lines in the casting, has much to do with the overall strength of the block. Nickle content and thickness too of course. For those who haven't seen it yet, there are many very good pics of blocks in this thread. Including some I posted with mold parting lines (posts 156, 157, and 158)
http://forums.maxperformanceinc.com/...g+lines&page=8
Old 07-09-2012, 10:40 PM
boodlefoof boodlefoof is offline
OK guys, I might have found a good candidate. Will probably go to take a look this weekend. Just wanted to double-check that I'm reading the date code correctly.
The owner says the date code is K036, which I read to be November 3, 1966. Sounds about right for a model year '67 car, right?
Other numbers... Engine ID code is XJ. Owner says he can read "86133" from the block casting code (probably 9786133?).
Old 07-09-2012, 10:48 PM
You, sir, have found the best 400 block available, a 1967 block. More than plenty stout for your needs.
The casting # and block code ID it as a 350 HP 400 auto trans block from a Grand Prix, originally equipped with casting # 670 high-compression heads (10.5:1 factory rating).
Way more practical than trying to adapt an early 389 block, the cost of a transmission adapter plate alone would easily exceed the purchase price of any good '67 400 block.
Leave the '59 -'60 blocks for the higher HP guys who need the ultimate in factory block strength, it's worth the trouble to come up with an adapter plate when you're building a max-effort race or super-street engine.
Old 07-09-2012, 11:28 PM
GRX's Avatar
GRX GRX is offline
Ditto on everything b-man said. Have one of those '67 blocks myself. Good find.
Old 07-10-2012, 11:04 PM
Well I got pics and vid... have to resize and probably edit video yet. Guess I'll get it posted sometime this week. lol
Great find on the 67 block.
Old 07-11-2012, 01:32 PM
Rocky 389's Avatar
Rocky 389 Rocky 389 is offline
As Steve said, using the 58-60 stick bellhousing and starter allows you to use a 59-60 389 and bolt up a modern style muncie, Liberty, T-5 or whatever. I've done it many times. Had very good luck using the 59-60 engines in my projects and I always use a manual transmission...usually a muncie 4 speed.
Roll around in the excitement
Old 07-12-2012, 05:46 PM
Well guys, I'll be going to go pick up (unless there is something obviously wrong with it) the '67 400 block on Saturday morning. I'll take some pics of the main webbing and lifter bores and post them up here this weekend for reference regarding the relative beefiness of various blocks.
Old 07-14-2012, 11:23 AM
I drove down and picked-up the block this morning at o'dark thirty. As promised, here are a few pictures. It doesn't look quite as stout as the SD block that was posted earlier in this topic, but is more solid than that 389 block picture.
On the casting number, the seller told me it was "86133." I presumed this was 9786133 and he just couldn't read the first two numbers. Now, I see why he couldn't read them... there is a tapped hole with a plug in it where the "97" would be. Anybody know what that is about? Is it factory?
Name:	2 bolt main 2.JPG
ID:	291127   Click image for larger version
Name:	block number.JPG
ID:	291128   Click image for larger version
ID:	291129   Click image for larger version
Old 07-14-2012, 11:31 AM
73 TRANSAM 73 TRANSAM is offline
The factory tapped it and is a 1/4" pipe thread. This is where you install the oil pressure sending unit.
Old 07-14-2012, 11:38 AM
The tapped 3/8 NPT plug is factory, it was put there to facilitate the drilling of the oil gallery. This location is commonly tapped into to take the most accurate oil pressure gauge readings.
Very thick lifter bore castings, a good sign. Missing the #2 main cap? If so it looks like a set of splayed outer bolt aftermarket 4-bolt caps are in your future.
Old 07-14-2012, 11:48 AM
Gator67's Avatar
Gator67 Gator67 is offline
Not this matters in this case. but I believe the "k" would signify Oct ("I" was skipped for 67 blocks from 66)
  #38
Old 07-14-2012, 08:05 PM
No, I've got it. I had just taken it off to check to see if the block was tapped for 2 or 4 bolt mains. Are the splayed caps a substantial improvement over factory 2 bolt caps?
  #39
Old 07-14-2012, 08:07 PM
Thanks, Jeff. Glad to learn another interesting tidbit.
  #40
Old 07-14-2012, 08:17 PM
Yes, but not necessary for a 500-600 HP street engine.
I wouldn't do anything more than use a stud kit to better secure the 2-bolt caps.
Substantial improvement at a very substantial added cost, you'd likely spend $800 or more to obtain the splayed caps and have the machine work to install them done properly. Honestly at that point for just a little more money you're really better off buying an aftermarket block that has all of the high strength features and upgrades.
