I recently had what looked like fuel pressure problems, similar to what you outlined here. But worse yet, my '70 GTO was dying when driving around in hot weather.
I had a little autometer fuel pressure gauge under the hood that was also giving me very, very low PSI numbers, like from 1psi to 3 psi vs. 5psi to 7 psi that we need I thought that my mallory 140 pump failed so I had that rebuilt and then I reinstalled it. Failed again! Then, I bought a new Holley HP 150 Long story short, the new HP150 dies on me also! Shortly after that happened, it started working again. What was different ? Heat! I realized that what I was experiencing was likely a form of vapor lock. I am running a factory fuel line and I figured that it was no longer cutting it, even though it worked OK for years. I took the car out of service, bought a new RobbMc sending unit (half inch), RobbMc regulator (bypass mode) and put in twin -8AN lines, including a return line. Problem solved. I should have done this years ago
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
READ ALL MY PROBLEMS I HAD HERE IN THE PY FORUMS, all because the way pump was mounted!! Fuel tank sumped??? Only way to go.
