Old 08-15-2012, 08:59 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Originally Posted by INJUNTOM View Post
BTW, I've had a smog license since 1993, so I know a couple things about this.
And let's not forget that they do roadside checkpoints looking for this stuff with a hefty fine to the owner of the vehicle and possibly the last person to have smogged it if caught.
I also know a few guys who are gold shield certified on smog among other things and everything you are saying is 100% correct. Doesn't mean people don't deliberately try and skirt the rules or that there isn't the occasional tech out there who will take a few c-notes to pass a grossly failing car, but it definitely isn't the norm and you should not rely on it. No legitimate shop is going to risk their expensive license, the hefty fines and dyno equipment they had to buy just to help some dude off the street. And if you're driving like an idiot or get a cop having a bad day and he pulls you over and makes you pop your hood, it's a world of hurt and fines if they catch you cheating.
You can theoretically put almost any Pontiac v8 in any car that came with one you want that is smogged here, they won't check for VIN numbers or block stamp codes (and even if they did 99% won't know how to read them anyways). But that emissions sticker on the core support must match everything in the engine 100% or you fail visual. Make it pass visual (easy), make it pass the pressurizer, and make it pass the dyno sniffer. There is a lot of leeway for a Pontiac 400 and 455 and I made my 400 pass with like 1/3 the max allowed NOx, 0.0 HC emissions, and almost no CO2 emissions as well. Very doable, but once you start yanking off things like EGR valves or having a carb\intake with no CARB number on them, you won't pass easily if at all even if you can make it past visual.
Old 08-15-2012, 09:44 PM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
Not so easy when EVRYTHING is gone. It will have to have an EGR intake, single exhaust with a cat converter, miles of vacuum lines, etc.
Not worth the effort every 2 years
Illegal smogs are harder and harder to get nowadays due to most guys doing it getting busted. And quite frankly, anyone doing illegal smogs in this day and age are utterly idiots. You eventually get caught. What a lot of guys don't think of is that we see 5 gases coming out of the tailpipe, the BAR sees a WHOLE lot more. I've had a BAR rep that I know show me some of the things they see, which is a whole lot more that what we get to see. Exhaust gas temperature and moisture content are a couple that I remember off hand. A car like the one in question would require a "clean piping" which means using another car for the test with the car in question's VIN number entered into the machine. They have computer programs that look for these things, and guess what? There's going to be another car out there that will have all the same readings (the one used for the clean piping), which quite frankly adds up to auto DNA.
And then there's the brainiacs who do "clean plugging" on '96 and newer OBD2 cars that has the smog machine plugging into the vehicle's onboard computer system through the DLC under the dash - guess what? You can get a vehicle's VIN number on your scanner screen by plugging into the car. The state SAYS that they can't get VIN data that way yet, but do you really think they are going to notify us when they do? Do you really believe them when they say they can't yet?
ANd then there's the whole camera issue - there's a camera port on the smog machine because they plan to someday film the techs doing the smogs, but they say they can't do that yet. Do we believe them?
Considering that you have to have a minimum of 2 years in the automotive field, be a top notch diagnostic and driveability tech, be certified in several areas of ASE testing, and somewhere around 150 hours of training in a BAR certified training course just to be eligible to take a test that has less than 50% passing rate in order to get the license, does it make sense to risk it all for a couple hundred bucks?
There are guys doing it, and the guy that I know works almost exclusively undercover going around and watching techs from down the street, on his laptop, etc.
I know a guy that got busted because the BAR parked a motorhome with a camera in it at the parking lot of the shopping center where his smog shop was and filmed him for daysn end.
AND... Hard to believe I'm sure {sarcasm} - they can watch your screen and everything you input into your machine from their laptop while sitting across the street from you while you have an entirely different vehicle sitting on your dyno.
No it's not fantasy stuff. It's what we know to be fact, but what about the stuff they don't tell us about? It is the government after all...
And the last thing any of us want is the surgeon general breathing down our necks...yes, the surgeon general. Smog issues are considered a health hazard here in commiefornia.
Old 08-15-2012, 11:16 PM
Ben M.'s Avatar
Oh I never said it was easy from where he's starting, just that passing visual is easy if you read the diagram and make everything match. They won't take the air cleaner off or verify individual vacuum lines, but it has to be really close. But yeah, starting with what he has is going to require tracking down quite a few parts...
Old 08-16-2012, 02:14 AM
INJUNTOM's Avatar
The smart ones will because that is exactly what you are supposed to do. That's one of the bad things about doing smogs in this screwed up cut throat business. You are meant to thoroughly inspect the car and the cut throat rates that these hungry guys out there advertise doesn't give you the time to thoroughly inspect the car.
You are signing an invoice that states that each component and system is intact, correct, and functions correctly. Unless that car looks as if it's never been messed with, I'm going to verify every vacuum hose.
The smog guy is up against undercover cars going through the shop, so unless you know the car, you'd better look it over well.
The worst thing is when one of these late 70s/early 80s vacuum hose nightmare vehicles come in and will obviously fail, you really have to look it over well to document which systems fail. You cant just rubber stamp it with a big F. You have to enter pass, defective, missing, modified, etc in every category like evap, egr, pcv, ais, cat, spark controls, tac, etc.
