Old 08-23-2012, 10:30 PM
65GPnoob 65GPnoob is offline
Default 454 in a 69 bird
Is putting a 454 worth putting in a 69 firebird?
Old 08-23-2012, 10:33 PM
tom s tom s is offline
if you want to reduce the value of the bird.Why not a 455?Tom
Old 08-23-2012, 10:37 PM
I have WZ400 4sp car,but the 400 is gone. It now has a pontiac 350 from a 68 bird. I was only wondering if it was doable because I seen a 454 for $200.00 on CL
Old 08-24-2012, 08:02 AM
The Boss's Avatar
The Boss The Boss is offline
Anything is doable, whether it should be is another story entirely.
If it's a real 454 it's probably a beat up truck motor and not worth the time & effort involved. I bet you could find another Pontiac motor that would be cheap enough and far easier to get in there.
And go racin' in the street.
Old 08-24-2012, 12:39 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
the previous owner of my 68 put a 454 in there, and he hacked up the subframe and the firewall due to fitment issues (Im assuming)
Its definitely doable, but it would be a PAIN
unless you find a Camaro that has rear end damage and can take the subframe
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
Old 08-24-2012, 01:09 PM
True. After I thought about the 454. I decided its not worth it to go to all that trouble.
Old 08-24-2012, 03:21 PM
WDCreech's Avatar
WDCreech WDCreech is offline
Good decision!!!
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
[email protected]/4, [email protected]/8, 1.1981-60-ft. 8/10/08
