#261
Put me down for a set for my white car.
#262
Put me down for a set for my white car, please
#263
The stripes are PERFECT in every way.....
#264
Hi Yellow Fever, THANK YOU for your interest in these. The kits are in stock and can be purchased from www.transamstripes.net
Just click on the 'Buy Now' button for the Blue Stripe Kit. Thank you again!
http://www.starspangledbannerchallenge.com/ |
#265
Hi Everyone, I'll be at the Trans Am Nat's this weekend in the vendors area, so if you're there, please come by and say hello. It's always great to meet friends from the Forums.
Show specials? Sure why not... I'll throw in one bottle of Rapid Prep and two bottles of Rapid Tac with every full kit sold. I'll also be selling individual letters, individual stripes and nose birds as well. Travel safe and see you there!
#266
The Trans Am Nationals were a great time for sure. It was terrific meeting so many ppl from these boards and others as well for the first time.
Thank you to those who came up and introduced themselves, and thank you also for so many positive responses to the stripes and letters products! I put together a display stand for POCI and the TA Nat's to allow folks to check out TransAmStripes.net up close and personal. Here's a few pictures of the display.
#267
very nice Greg, looks quite professional!
#268
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
#269
Sorry I missed you!
#270
THANK YOU! I appreciate the compliment. It did come out nice.
#271
Off the wall question. But, why didn't you mount one of the nose birds the correct orientation?
#272
I'll have to order on line.
#273
got to meet Greg and look at the stripes up close. it is a very professional display, and he is very professional also. he had some of his new stripes and the NOS stripes that he made the new ones off of. well i brought a couple NOS hood birds i had so i could compare mine to his just in case there might be a difference. all i can say is they are as good as it gets, just like NOS, but better. i have 2 sets of white car NOS stripes, but after talking to him and looking at these, more than likely i will use these on my 71.
nice to meet you Greg and the best of luck.(well with these you don't need luck, just need to get the word out)
FREEDOM ISN'T FREE BUT WORTH FIGHTING FOR |
#274
Thank you in Advance!!!
#275
I thought it would be best if the bird was oriented right side up so when folks walk up they could look at it up close. And, as 1971Warbird mentioned, he took his NOS nose bird and overlaid it on the bird on the panel to compare. Probably best if right side up for that type of detailed look. That's a long answer just to say I considered it for sure
#276
they look nice, my question is, it always seems like reproduction decals seem to fade out alot quicker than the originals. why is this and did you take whatever steps it would be to prevent it??? (if this has already been covered in the thread i apologize as i didnt read the whole thing)
very nice looking display. |
#277
). It's been through car washes and the truck is parked outdoors daily and still looks perfect, but I realize 9 months is not a long time and it's mounted vertical and not horizontal which makes a big difference to UV ray capture.I wonder if they are fading out strictly from sunlight, or from having chemicals put on them during waxing/cleaning/buffing? The reason I ask, is I sold a nose bird to a fellow at the TA Nat's last weekend who said he was cleaning road grime off the front nose with chemicals right before judging and swiped his rag across his bird and wiped the ink right off. He had already pulled the bird off by the time I came over to install the new bird for him so I wasn't able to tell who's product it was. I can however answer what I did producing these to prevent fading: - The stripes are screen printed vs. digital printing. This is how they were made originally and is superior to digital printing. - The inks used are the highest quality outdoor extreme conditions ink. As with most products there are average quality and high quality inks, and I can verify the high quality inks are more expensive as well ![]() - The graphics are clear coated with UV resisting clear after screening. - The substrate is the highest quality available on the market. The 3M cast clear vinyl is the same product that was used on the originals. There are other less expensive vinyls that are 'calendered' which are not extreme use quality. - The manufacturer is a high quality shop, ISO 9001:2008 certified. They made these stripes the same way they make graphics for OTR trailers with customers such as Walmart and Forward Air. I think a shop that maintains quality standards, including temperature and humidity and handling requirements will inherently yield a better product. - Finally, in the application instructions I recommend using only mild detergents for cleaning and avoid ammonia, soap, wax, synthetics and buffing. I'm sure original stripes got some of these products on them over the years which again doesn't explain why the new stripes are different than originals, but at least this care should give the owner the best chance of a long healthy stripe life ![]() I hope this information is helpful.
#278
1, ok Ill need a nose bird, not putting the original template to all these on my truck, but its gotta have one! great Idea ..
2, the guy had probably had windex on a rag after a window clean and wiped his nose ( no pun intended!) Have heard of this on new chrysler/dodge decals.. Windex.. Ammonia.... BEWARE! |
#279
i was flipping thru the current issue of High Performance Pontiac yesterday and noticed a nice little write-up on www.transamstripes.net. way to go G, you know you made it BIG when you get some ink in HPP
#280
When will the custom color options be ready?
Or are they, interested in one set for a possible race car application. How about sliver centers with a green fade. (Remember race car, lol...)
"Artificial intelligence is no match for natural stupidity". 1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph 1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.56 139mph |
