Old 09-16-2012, 01:01 PM
gtofreek's Avatar
gtofreek gtofreek is offline
They don't make front sump pans for Pontiac. The oil pump is in the rear so the sump needs to be in the rear also. If you fabricate one, you will need to remove the oil pump from the block, and use an external oil pump.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 09-16-2012, 05:57 PM
boodlefoof boodlefoof is offline
Forgive my ignorance on the topic. This will be my first Pontiac engine build.
So, nobody makes a pump with a shallower installed depth that uses a pickup tube that can be routed to the front?
